Question about GPS
Im having issues downloading loading a map from the dyno jet website.It saying there is something wrong with the file,please help
Posted by Vinnie Moran on
5 Related Answers
oldnovii
Jeffrey Pemberton
  • 667 Answers
SOURCE: dyno Labelwriter 330
Here is the link for your software. Just scroll down to get to your operating system and you can download everything you need. Hope you weren't waiting long. If this solves your problem please rate this as fixed. So many people forget. If you need more help just add a comment and I'll be glad to assist you further. Thanks. Please,dont forget to rate as fixed. Have a nice day.
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Posted on Apr 20, 2008
SOURCE: P4S800-MX Bios update
It could be that you have disabled BIOS flashing. Go to BIOS and look for the option and enable it
Posted on Sep 12, 2008
Anonymous
SOURCE: Nortech Navigator e-gps010 map updates
You can contact Ferro Works and they will send you a new CD with maps on it. They were not very clear on how updated the Version is. I called them and had a commitment of a new CD to be sent to me within fifteen minutes of dialing.
Here is the Info
619 Slack Street
Steubenville, OH 43952 USA
Tel:866-578-0101
E-mail:[email protected]
Posted on Oct 02, 2008
spyderdog8
Power cords are the same as Sirius power cords. I got one on E-bay and it works great!
Posted on Jan 06, 2009
lunasea808
lunasea808
  • 30 Answers
SOURCE: PSPTUBE FOR PSP3000
I believe in order to use psptube you need CFW (custom firmware) psp as it is a homebrew app. But the downfall with your psp is it as of right now there is no way to unlock your OFW (offical firmware) psp.
Posted on Jan 27, 2009
FOR WEEKS, I HAVE NOT BEEN ABLE TO GET THIS MUSEUM HOMEPAGE -- WHY? NBM.ORG
Windows 8 has had many issues and Im sorry that you're experiencing this issue. Here are a few suggestions:
1. Try using a different browser. Chrome may be bugged or just cant handle the website. I use Firefox and I just tried to bring up the site and it came up fine.
2. Try deleting your cookies and temporary internet files.
this is the best link I found. someone had the same issue.
https://productforums.google.com/forum/#!topic/chrome/t_Kkimn9vFc
I refuse to use W8 so unless you contact Microsoft, and uninstall 8, try my suggestions first.
Good Luck!
Sep 10, 2014 | Computers & Internet
I have a zx6r f1 1995 ninja. I recently had the downpipes changed on the bike. Now the bike struggles to go past 40mph. I have taken it to a dyno specailist and he as checked the carbs etc and hey are...
Hi, Melvin for openers you need to seek out an experienced professional technician that knows what he's doing, this isn't rocket science and Dyno's are a waste of time, money, and are brutal on your engine and if there is a catastrophic engine failure while on the Dyno guess who pays for a rebuild or a new engine, here's a little hint it won't be the Dyno operator or the company he represents. I have been in the motorcycle business 35 years and worked on thousands of bikes and never once needed a Dyno to help diagnose a performance issue.
If you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
1. Closed to 1/8 throttle is managed by the air screw and pilot/slow jet.
2. 1/8 to 1/4 throttle is managed by the air-screw, pilot/slow jet, and throttle slide.
3. 1/4 to 1/2 throttle is managed by the throttle slide and jet needle.
4. 1/2 to 3/4 throttle is managed by the jet needle, needle jet, main jet, and air jet.
5. 3/4 to wide open throttle is managed by the main jet and air jet.
6. Wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
zx6r 1995 1996 1997 Team Kinkos Muzzys carb tuning factory pro eddy...
Carburator Theory and Tuning
Kawasaki 1994 Ninja ZX 6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 19, 2017 | kawasaki ZX-6R Ninja Motorcycles
I only have the dyno jet i dont have the usb peace whats an even good point to set the fuel at directly from the box with the 3 buttons its self?
The power commander uses a mini-b USB cable that you can get at most any electronic store or Walmart for next to nothing.... if you've got a digital camera, you've probably already got the cable you need. You'll just need to download the software for the Power Commander from http://www.powercommander.com/downloads/Support-Released/PCIIIUSB/Software/PC3Usb%203.2.1%20Setup.zip.
Once you've installed that one your computer, you'll be able to tweak your fuel map however you want. I would recommend making a backup of the fuel map that you're running right now before making any changes, that way you can go back to stock without any trouble. Dynojet's website also has canned maps for all kinds of bikes that you can download, and for the most part they work great.
Mar 01, 2011 | Dynojet POWER COMMANDER III USB HARLEY...
Garmin Nuvi 660 map is lagging behind position
Sounds more like a problem for garmin, but here are a couple of maybe suggestions. Go into the settings menu and see what is displayed IE rest areas, gas stations, restaurants, things like that, the more "things" you get out of the display the faster the units response time will be, it also sounds like you might have loaded the wrong screen size onto the unit when you upgraded the software however that i can't say one way or the other on. Final note the more things that the display has to show you the slower the unit is. Hope this helps
May 10, 2010 | Garmin Nuvi 660 GPS Receiver
HP increase at elevation using a Dyno Jet Dyno?
same dyno? same operator? theres something wrong. the lower altitude the better, as far as I know. But someone thats smarter than me and has high altitude /dyno experience would be better to answer the question.
Oct 01, 2009 | 1983 Mazda RX-7
No Maps found on TomTom One XL
You were able to successfully download windows files with your Mac and transfer them to your Tom Tom? I'd suggest trying the transaction again, but doing it with a windows machine. (Trust me, I have a Mac and I realize how unwell it likes to play with Windows.) {But I wouldn't trade it}
Aug 20, 2009 | Tomtom ONE XL GPS
Iv got an backup issue with my tomtom one.after backup with microsoft windows xp backup and restor software,i wrongfully formated my tom tom one,now when i restor my backup with windows xp...
I do some work with TomTom - it's possible that if something interrupted or went wrong during the install, the map could have been deleted. TomTom is aware of the problem and is working to fix it - if you are map-less, call support (866 486 6866) and we can work on getting you a new map.
Jun 08, 2009 | Tomtom ONE XL GPS
Maps
power commander website; customer service; try to pick a map w/similar intake/ exhaust listed; P/C is not an exact science w/o a dyno. thats what makes it good for shade tree guys you can change maps a dozen times a day and see how it rides or find an indy dyno shop and have them tune it right the first time. it may be a big nut but in the long run a GOOD shop will save you time, money and a head ache down the road...make sure they have a dyno though or else they are just guessing too albeit an educated guess but still a ballpark. a dyno can dial it in!
May 24, 2009 | Dynojet POWER COMMANDER EX III USB -...
Ok I have two problems on Xbox 360. The first one im going to explain is on Halo 3 for some reason I can't play the online maps Isolation and The Pit. I don't know if it's because the disk is scratched or...
Clear patches by going to systems then press y, once you go onto the page, press x,x, LB, RB, xx a message will pop up saying something about maintanence, say yes. this remove game patches and are easily fixed by reconnecting to live. This should fix your issue.
Apr 22, 2008 | Microsoft Xbox 360 Console
TomTom One Europe
What is happening is your map updates are being copied onto your memory card without overwriting the old maps hence you are running out of memory.
In the tomtom home browser you should be able to delete your old map before installing the new one. Make sure you have a back up of the map card before you try this though so you can reinstall if something goes wrong.
Also have you replaced the voice prompts on your tomtom? The voice files take up a lot of memory so if you have put new ones one without removing the old ones you will be wasting memory.
There is one window in TThome that lists eveything installed on yuor card so have a good look at this and see what you can get rid of.
Oct 30, 2007 | Tomtom One Europe v2 GPS Receiver
GPS Logo
126 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
