SOURCE: Block Numbers
you have to download the software from download.com. just look up pda/smartphone software.
CallFirewall - a freeware smartphone app
Whitelist, only callers and/or sms from list
Blacklist, no callers and/or sms from list
Accept only from contact list
Reject All Calls
Reject all calls beginning with ### (i.e. an area code or provider like everything beginning with 800)
Reject and send the rejected callers an sms message
SOURCE: blocking unwanted numbers
Normally you can so long as the caller is presenting their number through Calling Line Identification (CLI) - ie you can see the incoming number on the screen.
If you can see the number, save the number into your phonebook. Create a Group in your phonebook and put the number in it. Then normally you can automatically reject calls from a Group - either by the Group options, or by the settings under the phones Profiles.
SOURCE: Unwanted calls
You can't prevent anyone from calling or sending texts to your number, but you can easily set your Nokia 1112 to ignore the calls as follows:
Menu -> Settings -> Call Settings -> No. Screening -> Options -> Add
You can also retrieve the number to screen:
Menu -> Call Register -> Received Calls -> Options -> Add to scrn. list.
Calls from screened numbers will not ring on your phone, you will see the number on your screen with a dustbin symbol; messages from screened numbers will go silently to the screened messages folder.
I hope this helps.
Regards,
Rob
