Question about Nikon Cameras
This command may be somewhere in the menu system - failing that, look it up in the manual.
Posted on Dec 09, 2018
SOURCE: Nikon coolpix p1 camera takes weird outdoor pics
If the playback of old pictures are fine but camera mode displays lines across, you may have a defective CCD chip. These are expensive repair averaging around $110. Some local shop may able to repair it. Good luck -James. For further assistance by email, go to www.camerarepairjapan.com
Posted on Mar 27, 2009
SOURCE: Nikon CoolPix S5. Red flashing hand. Camera/Lens on/open.
If the shutter is stucked there is no external way to release it Have to show it at camera shop
Posted on Apr 03, 2009
SOURCE: Mode Dial and Lens Problems! Nikon Coolpix 4600
i had the same problem try this: tap the outside of the dial lightly while turning the camera on it should basically "pop" right out!!!!!!!!;)
Posted on Dec 08, 2009
SOURCE: I dropped my Nikon Coolpix 4300. The camera will
It is probably a connection problem. I removed the 9 screws from the bottom and 2 sides of the camera, opened it slightly and snapped it shut after looking within.. The problem cleared. Bring it to the service center if you feel you can't put it back together again after you open the case. It is not a card issue.
Posted on Dec 01, 2011
SOURCE: Nikon Coolpix S8100 and when I turn it on it says Mode Dial is not in proper position
Return the camera right away, it is clear this is a manufacture defect, nothing more can be done.
Posted on Mar 23, 2012
