HOT coming from hose checked. HOT turned off at valve- water come in cold when on HOT setting. HOT and COLD on then water is room temp when set on HOT. COLD turned off at valve and water is HOT when set on HOT. Checked screens. Mixing valve? or board?
SOURCE: No hot water
Make sure your hot water supply valve is on first. If so then try reversing the hot and cold water feed lines and see if you get hot water when asking for cold. The water valve for the hot water side could be bad. Are you familiar with a voltage meter or know someone that can see if you valve coil is getting 120V when the machine is trying to fill with hot water. If not the control unit is faulty. If you do have the 120Vac on the solinoid coil and no water the either the coil is open circuit(bad) or the inlet is plugged. Most generally the problem is in the control knob unit.
SOURCE: LG Tromm hot water only
i have found the water inlet valve bad and also the main control board can cause it
SOURCE: Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
SOURCE: Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
If you turn off the hot water line, and you have cold water then suspect the water inlet valve. Unplug the unit and turn off the water to disconnect the water hoses. Pull out the washer and remove the back of the unit by the water hose inlet. The new valve is around $65.00 and is on connectors, which make it an easy fix.
If that’s not the case, valve is most likely defective
Checked the hoses and they are correct. thx
