Question about Rolex Watches
Looking for a production date on a watch. Ser # 606321v1. Also did that watch come with a grey diamond dial?
I m questioning the dial because I'm thinking it might be aftermarket. Also is J.C. Pennys authorized to sell pre-owned Rolex watches if they've been serviced buy Rolex authorized service center.
Posted by Glen on
5 Related Answers
Anonymous
  • 43 Answers
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Posted on Jan 05, 2009
Anonymous
  • 43 Answers
SOURCE: rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Anonymous
  • 26 Answers
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Posted on Jan 06, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
David Shaub
  • 2976 Answers
SOURCE: I had my Rolex watch serviced 2 years ago By Rolex and now
Either the stem or latch needs to be replaced. It's a common problem for ALL manual wind watches.
Posted on Dec 06, 2009
I have a ladies wave, two tone, dia dial. Can I buy a diamond bezel for this. Where and how much would it cost.
I can pull out the crown 1 step to adjust the date and another step to adjust the time but not completely. I looks also like e screw but is that really the case? Do I have to use a lot of force to get the crown out?
Jan
Oct 14, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
I have a 3 dial AK watch. I can't seem to adjust the date and day.
You can pull out the stem on the side there is a halfway setting one click out, turn one direction for day and other direction for date, two clicks out sets time.
Aug 27, 2011 | Anne Klein AK Anne Klein Diamond watch...
Perpetual 100m 6a32. I had the battery replaced, and now the date is not square in the window. The window shows the bottom of todays date and the top of yesterdays.
Try pulling the crown wheel (winder) to position 2 (1 is fully in, 3 is fully out and 2 is in the mid position).
Turn the winder anticlockwise slightly and this should move the date until it is the correct position.
May 04, 2011 | Seiko Perpetual Calendar with Dark Silver...
HOW DO I CHANGE THE DATE ON MY MICHELLE DECO WATCH
Turn the dial toward you and pull out. Then turn the dial away from you to change the date (you can only go upward in date).
Mar 09, 2011 | Michele CSX Diamond watch
Change date on my invicta 6676
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all INVICTA watch manuals.Rate me, please.
Mar 18, 2010 | Invicta Diamond - DIAMOND LADY'S DOME...
Setting a Kenneth Cole Digital RK1202 watch
you can find an exper in the local shop where you buy the product and they will give you specific service for your questions about your product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to buy world of warcraft gold with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service when your login.
Jan 07, 2010 | Kenneth Cole KC1232 Wrist Watch
Ladies Classic Wave Diamond dial
Yes, you can. Contact your nearest Ebel retailer and they will advice you.
Bear in mind- this is a costly upgrade.
Jul 19, 2008 | Ebel Classic Wave 9090F249725 Wrist Watch
RECYCLE MY DIAMONDS
You should go to a diamond store and ask if they can do that for you .Your welcome.
Dec 30, 2007 | Lancaster Diamonds Luxuria - Pillola White...
Two cheap chronograph watches that won't set date and month
I would need the models on all watches to answer this question. I would make sure that the crown really doesn't pull out to a second position. They can be a little stubborn sometimes.
Dec 22, 2007 | Invicta Chrono Cube Diamond 9905 Wrist...
Watches Logo
73 people viewed this question
Top Rolex Watches Experts
Bruce Robin
Janelle Schoonover
Janelle Schoonover
Are you a Rolex Watch Expert? Answer questions, earn points and help others
