Question about Camping, Backpacking & Hiking
I have a 20 million candle power and I need a switch or how to fix it
Posted by Daniel Sayese on
5 Related Answers
Anonymous
SOURCE: I need 3 light bulbs for a 3 million candle power
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
Posted on Jul 13, 2010
Anonymous
SOURCE: how do i find charger for cyclops 15 million candl...
INPUT: 120VAC 60Hz 18W
OUTPUT 12VDC 1A.
This is the spec for the 18 million thor cyclops which i presume will be the same for the 15 million.
Red light on torch flashes while charging. As soon as full charge is done red light stays lit.
CarlGlas
Carl Glas
  • 283 Answers
SOURCE: I have a Sport Spot
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Or you may find one here: http://www.batterywholesale.com/battery-store/SLA-batteries/
Posted on Nov 03, 2010
Anonymous
SOURCE: I have a Vector VEC 189 10 Million candle power
I have this same light and have lost the charger. can anyone tell me where to get one. Thank you
Posted on Apr 01, 2011
Conrad Jacoby
  • 172 Answers
SOURCE: I have a victorlite 1.5
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Posted on Jul 13, 2011
Testimonial: "SO PRETTY MUCH DOESN'T MATTER- THANKS SO SO MUCH!! "
Power pro Craft 15 million candle power rechargeable halogen spotlight HSLR15M need charger information.
I have a PowerCraft Pro hslr15m
the power adapter is DC15V 300mA
CENTER POSITIVE
does anyone have info on the bulb?
Sep 24, 2013 | Camping, Backpacking & Hiking
I have a Sport Spot 20 million candle power light .I need a battery for it .Battery number NTO609(6v6 OAH/20HR). Where can I find it, and how much will it cost?
Sep 29, 2010 | Vector 2M Pwr Rch Spotlight
How do i find charger for cyclops 15 million candle power
OUTPUT 12VDC 1A.
May 19, 2010 | Camping, Backpacking & Hiking
The small flashlight on the handle will not turn off. When I press the button it goes off and then when i release it comes back on- can you assist?
It sounds like your switch is defective, unfortunately Vector lights are Non-Servicable except for replacement bulbs, batteries and chargers, so I don't think it is worth fixing.
Mar 19, 2010 | Vector Spotlight - 1 Million Candles...
I need 3 light bulbs for a 3 million candle power spotlight from Gordon 12Volts
Mar 08, 2010 | Vector 3 Million Candlepower Rechargeable...
I have been charging my 2 million candle power spot light for last 2 days but full battery charge indicator (red light) does not flash yet. the led white light is working but the main lamp doesn't work....
It should take 10-12 hours, any longer the battery is no good, you can test the battery using a Volt Meter, the battery should be reading 12 volts, any less and the battery will need to be replaced. You can order a new one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Feb 13, 2010 | Vector 20 Million Power Series Spotlight
I need a 90 watt bulb for my 15 millon candle watt
Check Home Depot, they should have it, if not in the store then online
Oct 08, 2009 | Vector 3 Million Candlepower Rechargeable...
I am looking for a 1 million candle or more hand
Try this link, lots of good sugestions under $20. Your local Kmart/Wal mart or Meijer should have them also try Home depot or Lowes as well
http://shop.ebay.com/i.html?_nkw=cordless+candle+power&_sacat=0&_trksid=p3286.m270.l1313&_odkw=rechargable+candle+power&_osacat=0
Aug 06, 2009 | Seachoice Products Compact Halogen...
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Camping, Backpacking & Hiking Logo
381 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Kardoc
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
