Exercise & Fitness Logo
Joe Bradley Posted on Dec 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a nordic track t5zi. It wont turn the belt and the motherboard blinks 4times. I replaced the motherboard and the drive motor and still get the same
Jesse Garza
Level 2:
  • Expert 84 Answers
  • Posted on Jan 02, 2019
Jesse Garza
Expert
Level 2:
Answers
84
Questions
0
Helped
20778
Points
254
Check to see if there is a smaller board in the unit. There maybe relays between the main board and the motor.
5 Related Answers
Anonymous
  • Posted on Feb 19, 2009
SOURCE: operating manual for cx1050 nordic track ellpitical
http://www.iconservice.com/pdf/NEL12940.pdf
I just downloaded a copy. It's 32 pages.
Anonymous
  • 3 Answers
  • Posted on Feb 20, 2010
SOURCE: I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on May 14, 2010
SOURCE: how do you adjust or tighten the belt on the
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
Anonymous
  • Posted on Jul 10, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Anonymous
  • Posted on Oct 29, 2010
SOURCE: Have a nordic track exp 1000x treadmill and the
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Nordic Track T12 si , belt won't run
If the belt on your Nordic Track T12 si treadmill is not running even though the display and other functions appear to be working, there are a few troubleshooting steps you can try:
  1. Check the safety key: Ensure that the safety key is properly inserted into the console. The treadmill will not operate if the safety key is not securely in place.
  2. Reset the treadmill: Turn off the treadmill and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can help reset the treadmill's internal systems and may resolve any temporary issues.
  3. Calibrate the incline: If you recently used the incline function, it's possible that the calibration of the incline mechanism is off. Consult the user manual for instructions on how to calibrate the incline. This process may vary depending on the specific model of your treadmill.
  4. Check the motor and drive belt: Inspect the motor and drive belt for any signs of damage or wear. If the drive belt is loose or worn out, it may prevent the belt from moving properly. If necessary, consult the user manual or contact Nordic Track customer support for guidance on inspecting and adjusting the motor and drive belt.
  5. Lubricate the belt: Insufficient lubrication can cause the belt to stick or not move smoothly. Refer to the user manual for instructions on how to properly lubricate the treadmill belt. Use a silicone-based lubricant recommended by the manufacturer.
  6. Contact customer support: If none of the above steps resolve the issue, it is advisable to reach out to Nordic Track's customer support. Provide them with detailed information about the problem and any troubleshooting steps you have already taken. They will be able to offer further assistance, including potential repair options or guidance from a technician.
I have a Nordic Track C2255. When I turn it on the motor run, but the belt won't move. I'm thinking that replacing the MOTOR CONTROL BOARD would solve the issue, but need to know before I spend the $.
You must observe 3 things:
Open the cover from motor
1) See if the Drive belt or belt for motor is Loose?
if does, adjust the 2 bolts for tension belt motor the deflection will be 1/8"
2) or Too tight loose the 2 bolts , and loose little until you have deflection for 1/8" and tight the bolts again, keeping the deflection for 1/8"
3) See if the belt is Cut!! replace it, by new one.
Blessing
[email protected]
whatsapp:+50588611441
T5Zi treadmill walking belt motor won't start.
Normally when this happen the controller board motor is faulty.
However you must see the schematic diagram , and the thermo switch inside of motor, if is defective or o.k. YOu must use the DMM, for continuity and test if closed or open.Replace or replace.
Of course you must test the main motor, with Battery 12Volts for for to see if the motor is working or defective.
Blessing.
[email protected]
cell+whatsAPP:+50588611441
Testing treadmill motor speed control
1helpful
Incline settings reversed
the wires for the incline motor are reversed on the board.if you follow the wires you should have 2 that look identical. reverse where they connect on the board and see .
How to t6.3 drive belt adjustment
Afix the drive belt onto the drive motor flywheel, then force the drive belt onto the roller pulley by turning the roller
How do I replace a Nordic Track C2255 drive belt?
The black shavings are normal on a treadmill. It may be that you need to tighten the walking belt. Try tightening the two bolts on the rear of the machine that hold the rear roller in place. You need to tighten each of them the exact same amount or you'll throw off the alignment. Tighten them three turns of the wrist and see if that helps. If not, try three more turns. If still nothing then replace the drive belt. That can be a real undertaking and you might want to consider contacting a professional.
Belt is slipping. we have adjusted the belt but it seems the adjustments don't "hold".
Here is a tutorial on adjusting your treadbelt: http://www.fitnessrepairparts.com/tutorials/adjusting_your_treadbelt.php
If you need to replace something here is a list of parts: https://www.fitnessrepairparts.com/equipment/Select/15401/NordicTrack/NTL610090-T5zi
You may simply need a local service provider to come look at it, you can use Google or enter your zip code here: http://www.fitnessrepairparts.com/find_a_servicer.php
1helpful
Belt on nordic track exp 1000 not moving today but worked this week. machine turns on though
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
1helpful
I turn my treadmill on and it immediately goes full speed
That sounds like a motor control that is shorted out,the only thing you can do is replace the motor control.When replacing the controller follow the instructions to calibrate it to the console.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
