There are no user serviceable parts, the power unit may have a fuse or capacitor that has failed. If you want to look into fixing it then it could be a long haul with lots of test gear. On the other hand you may be able to get just the power board.
Testimonial: "Thanks. If I picked up a used remote could it by pass the on/off switch?"
SOURCE: KR-X1000 Power Problems
Sorry, no freebies from what I see online. But, when you power up, does it play before it shuts down? This will help me formulate a better answer for you...accordianman
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
SOURCE: service / owners manual for KENWOOD KR-920B
This is as close as you're going to get:
http://inform3.kenwoodusa.com/manuals/kr910.pdf
SOURCE: need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF]
Cox Manual
File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
www.xdiv.com/remotes/ - 73k - Cached - Similar pages
www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
SOURCE: My Kenwood KR-V5570 receiver powers
i had exact problem.
the bare wire speaker cables that connect via a clip connecor in back of the receiver are pushed too far in. something inside is shorting out with the speaker cables. solve this issue by either tightly twistng or soldering the wire ends ( then clip the ends about 1/4 inch long). watch out for the same issue of electrical shorts at the speaker end of the cables.
