Question about Durabrand Audio Players & Recorders
SOURCE: durabrand db1210
burning to fast maby try updating software u burn with use nero
Posted on Feb 10, 2008
SOURCE: Durabrand HM3817DT
Just in case you try to follow directions like me, make sure that you have removed the cover inside the cd slot. No, directions aren't great. They are as difficult as any I have ever seen, but when I tipped the unit up, I saw a note on the bottom of the cd shiny cover that says remove before playing. After removing the flat cover press the button to turn the light off. Light on means standby, not on. Insert cd and push function. Then push play/pause button on right. Hope this helps. If not, return to store.
Posted on Dec 26, 2008
SOURCE: Durabrand CD Home Music System - Volume default
HM3817DTBLK:Default volume
I sent a note to the manufacturer. Communication attached below.
Dear Customer,
We thank you for your interest in GPX and our products. We apologize, but the volume level on the unit is a factory setting that we are not able to override or alter.
Once again, we apologize for any inconvenience this may have caused.
Best Regards,
GPX Consumer Service
>>> "Chris" 12/27/2008 2:02 ">[email protected]> 12/27/2008 2:02 >> PM >>>
The default volume is set way too high on this radio. It is at 17 and we would like to reset it to a much lower level. How do I do this?
Chris
Posted on Jan 05, 2009
SOURCE: Durabrand model HM3817DT radio/CD player- cd eject,radio volume
Durabrand products are prone to alot of problems!!! In other mords they really ****!!!
Posted on Aug 25, 2009
