Question about Optics
SOURCE: won't start
Clean connections with sandpaper until shiny and tighten all connections. Measure the voltage with one lead at the battery positive and the other at the starter (voltage drop). It must be 0.4 or less. If more, you have bad connections or a bad cable.
Posted on Jun 02, 2009
SOURCE: GOT A 99 GMC SONOMA. THE VOLT GAUGE WAS SHOWIN
11-12 IS GOOD WITH RUNNING NOTHING ON WHATS IT ON . NOW TURN JUST HEAD LIGTHS ON DID IT MOVE ANY MAYBE 1-2 METERS THATS FINE . DRIVE IT!!!!!!!!!!!!!!
Posted on Dec 12, 2010
SOURCE: The battery for the red dot finder scope on my
Most red dot finders use a small watch style battery-- there will either be a compartment underneath and or something that opens on the side that contains the watch battery.
Posted on Jul 13, 2011
1) memory card slot/batter covert is open
2)batteries are loades in the wrong direction
3) insufficiente battery voltage
4) poor contact between camera and battery terminal
5) swtich is fault, measure continuity.
God bless you
Posted on Oct 17, 2012
SOURCE: 1994 olds cutlass supreme volt gauge shows low
You either have a bad meter or a bad ground to the meter if you have full battery voltage at the meter location.
Posted on Feb 13, 2013
Jun 11, 2011 | Barska Optics Barska 1x30 Red Dot Scope...
May 02, 2011 | Barska Optics Barska Riflescope Excavator...
Apr 06, 2011 | Barska Optics Barska AC11202 - 4-16x50...
Jan 24, 2011 | Tasco 1x30 Red Dot Sight BKRD3022
Jul 06, 2010 | Barska Optics BARSKA 1040X50 AO Varmint...
Mar 25, 2010 | 1994 Oldsmobile Cutlass Ciera
Apr 18, 2009 | Barska Optics Barska® 50 mm Red Dot Scope...
Apr 13, 2009 | Tasco ProPoint Red Dot Matte Red/Green Dot...
Apr 04, 2009 | Barska Optics Barska 10-40x50 Ao Varmint...
253 people viewed this question
