Question about Haier Refrigerators
I have a haier mini fridge. It was in the corner of my room, I moved it to clean behind it. I was very careful moving it. It was still running, but a few moments later I heard a "ping" type noise and it stopped working, sounded like metal? What happened and how can I fix it? I tried the outlet and the still works.
Posted by Sarah Kuhlman on
Brian May
    New Friend:
  • 3 Answers
Unplug for a day then plug back in. If it won't start it's probably the compressor overload
Posted on Dec 08, 2018
5 Related Answers
ltfrc
Mike Schmidt
  • 227 Answers
SOURCE: moving tv to another cable outlet
I f you have cable at the new location follow it back to a splitter. Remove the one you used to use and screw in the one you want to use. They should all terminate at the same location.
Posted on Jan 18, 2009
Anonymous
  • 46 Answers
SOURCE: Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
Posted on May 26, 2009
George Fleming
  • 142 Answers
SOURCE: Haier hsp03wna not working
The click you heard is the thermal overload. This snaps open when the compressor is too hot.
Unplug the unit for 24 hours and don't move it.
Then plug it in and see if it comes back on temp.
Posted on Jun 02, 2009
Anonymous
  • 72 Answers
SOURCE: Air or gas leaking from freezer in Haier mini fridge
If you go to a refrigeration supply the sell an epoxy to repair the evaporator but you will need to do a sealed system repair
Posted on Jun 07, 2009
johnjohn2
Johnny Brown
  • 5763 Answers
SOURCE: My speedometer on my Suzuki
This sounds like it may be due to a bad speed sensor but the best way to find the problem is to have the codes from the engine light read,the computer stores codes that will tell you what has failed, there are many auto part stores that will scan the computer and give you the codes, the code will tell you what has failed, if you can give me the code i could help you better. good day.
Posted on May 01, 2011
Moved the fridge and when we plugged it in, it wont come on
has to be left standing not plugged in at least 24 hours . for the oil to run back to the compressor
Jul 25, 2015 | Haier 40D3500M 40 1080p LED-LCD TV - 16:9...
How do i defrost haier hnde03vsbj fridge?
Leave it off for 24 hours. Clean out the water and start it up again.
Aug 07, 2014 | Haier Compact Small Refrigerator 1.7 Cu.ft...
Inside strip of fridge is very hot. cleaned out behind fridge and the coils, etc. fan is barely moving/not moving. any suggestions???
Replace the fan. The strip has a freon line running behind it, and when it is hot, this tells us that you have a dirty condensor, bad condensor fan motor, bad evaporator fan motor, defrost problem, or a freon system problem. When you say your fan is barely moving, I am assuming this is your condensor fan motor, which sucks air through the hot freon lines in the condensor coils, and cools the freon off. If it is barely moving, it can't cool the freon. In some brands a slow moving condensor fan can be caused by a bad main control board. Good Luck, Appliance Specialists
Jan 28, 2010 | Refrigerators
Fridge won't start up.
have you tried testing the plug. Has the fuse blown in it? try changing the plug to see, then if this doesn't work try a different power outlet.
Sep 07, 2009 | Haier HNSB02 Refrigerator With Ice Box
My fridge will not cool. I hear it running non stop, there is a trickling water sound, but hardly cools. I had it set at "4" for over 24 hours, and then moved it to the max. At both settings, the freezer...
You have a refrigerant leak sorry I suggest to get a new one because they are not wort to repair then unless you happen to do that for a living. will cost you more to fixed than the fridge wort. :(
Jun 10, 2009 | Haier HSB03 Compact Refrigerator
Freezer is working but fridge is not cooling
is the evaporator fan (in the freezer) running? if not you cant move the cold air from the freezer too the fridge. also make sure the return air duct is not blocked. air moves from freezer, through fridge and back to freezer.
May 25, 2009 | Haier RRTG21PAA Refrigerator
Clicking near compressor but doesnt run not even a year old haier compact mini fridge
since your mini fridge is under warranty, have a technician come and take a look at it. i would say it's the damper.
Sep 13, 2008 | Haier Refrigerators
Refrigerators Logo
66 people viewed this question
Top Haier Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
