SOURCE: All Surface elements are dead
Sounds like you might have a bad oven surface control board also called power board. The part # is 316239400. It is located on the left hand side about mid way down on the back of the oven. First, disconnect power and make sure all connections on board are tight. Plug back in and make sure you have power to that board if possible with a meter. If all check ok then the board is bad.
SOURCE: compressor not running, front display flashing "CF"
have you tried to see if your getting voltage at compessor?? it sounds like relay/overload is bad have you replaced it?
if not, try that i'm suspecting that's the problem
SOURCE: Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
SOURCE: whirpool fridge/freezer, wmb39lw have replaced front interface board but the fridge is still beeping
How many beeps and is there a sequence?
