Question about Food Processors
SOURCE: Black and Decker Shortcut Food Processor
I just bougth this processor on weekend. Have you found a book yet. If not I can email it over to you in pdf format. Let me know. Email me at [email protected] and put in subject line, food processor. thanks
Sheila
Posted on Feb 16, 2009
SOURCE: It just stopped working
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Posted on Mar 24, 2009
SOURCE: My Cuisinart food processor won't start!
Make sure work bowl handle is locked in so that the handle is facing the front of the processor, and that the feed tube and metal rod of the pusher are facing the back of the processor. If it is assembled in this way and still won't turn on, call Cuisinart for assistance, as you may have concelaed damage to one of the work bowl parts. 1-800-726-0190
Posted on Sep 29, 2009
SOURCE: I have a Cuisinart 14 cup food processor which will not turn on
Hi-
We have a Cuisinart and these tools are very rugged- so I doubt that the motor is bad. My only suggestion would be to make sure that the safety catch is being actuated when you click the cover clockwise to secure the mixing chamber. There is a hole in the housing that the acuator pin sticks into to disengage the safety switch. Perhaps the switch is not being pressed off.
Hope this helps,
Jeff
Posted on Oct 28, 2009
Aug 24, 2018 | Cuisinart Food Processors
Aug 19, 2018 | Rival Food Processors
Mar 29, 2015 | Hamilton Beach 702R Food Processor
Nov 13, 2009 | Cuisinart DFP-14BC Custom Food Processor
Oct 11, 2009 | Cuisinart SmartPower Premier Duet...
Sep 17, 2017 | Hamilton Beach 702R Food Processor
Sep 19, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Aug 14, 2008 | Cuisinart DLC-5 Food Processor
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
223 people viewed this question
