Question about Bose Audio Players & Recorders
I have abose av3-2-1 my remote stoped working so i purchased a bose universal remote. i can not get it to turn on my bose system. need help. thank you.
Posted by richard marty on
5 Related Answers
Anonymous
SOURCE: need a universal remote control code for sony dav-dz 100
1903 will work for most functions, but not the DVD player buttons.
Posted on Dec 26, 2007
Anonymous
SOURCE: Innovage jumbo universal remote code
try this website, you have to scroll down and find "Innovage" on the list and then it will download the pdf of the manual.
http://www.xdiv.com/remotes/
Posted on Jan 03, 2008
Anonymous
SOURCE: Bose lifestyle 25 system and Panasonic Plasma Tv not working together
I posted the message as Tet Tet before. I can now tell you that I have resolved the problem. The issue is with the Panasonic 50Inch TV. Some people reported the same problem but only when the TV was up on the wall. It turns out that the problem lies with the metal discs which screw on at the back of the TV to enable you to hand the TV on the wall bracket. In my case I had excessive interference caused at the back of the TV (could be the fan). When I put the TV on the wall bracket the metal discs would be in contact with the wall bracket which in turn was acting as an antenna causing the iterference to the bose remote which operates at a frequency of 27.45MHz. You can solve the issue by adding some insulating tape around all the metal discs avoiding them to make contact with the wall bracket. If that fails Panasonic will swap your TV for another one like they did with me. I can now enjoy my Bose System with the 50 inch Panasonic TV. It took me three months but managed to get a solution. I hope this helps. For further info you can mail me at [email protected]. These discs should be made of metal because they are perforating the metal screen at the back of the TV. Panasonic please change this design.
Posted on Jan 16, 2008
Anonymous
SOURCE: Bose 321 Remote not working
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Posted on Jul 04, 2008
Anonymous
SOURCE: I need a replacement remote control - Bose RC9
I have same problem with RC-9 working intermittently with some light banging. Thanks for the tip above. I tried opening the remote but the case wont open. Is there an easy way? Dont want to break the case while opening. Thanks.
Posted on Dec 29, 2009
Bose solo sound system
Does the Bose remote work at all? New batteries may fix the problem. Logitech Harmony universal home theater remote and app This the best remote control you can ever have for your system. It is amazing. No need to look up codes since the remote is programmed all at once for every component you have and it's done online at their website. Want to change or add a new component? No problem....just log back on to their web site and edit your settings.
Sep 07, 2016 | Bose Solo TV sound system - Black
Can you turn it on without the remote? My dog got a hold of the remote and I need to turn it on so I can try to program it to our cable remote.
Learn To Bose Solo TV Sound System 44902 - YouTube
? 2:12
https://www.youtube.com/watch?v=QQziZ3w6z0A
Jun 22, 2015 - Uploaded by Lisa Tiffany Knowles
Learn To Bose Solo TV Sound System Review Read More reviews from Amazon Buyer: ... I received this sound system withno knowledge of what it really is. ... The rep that I worked with (they assign you one person to talk to--a real. live person who emails you ... bose solo tv sound system universal remote
Solo 15 II TV sound system - Bose product support
worldwide.bose.com/.../en_us/web/solo.../page.html
Bose CorporationThe Solo 15 and Solo 10 series II systems dramatically improve television sound. ...Follow these steps to program your Bose® universal remote to control the other ... high quality home theater sound from your Bose system, you should turn off
Jan 05, 2016 | Bose Solo TV sound system - Black
I am having a Bose Cinamate Digital Home Theater. Original remote of this was lost and bought a new Bose Solo/cinemate system universal remote. It doesn't function with the interface. Will it real
If you can't get this to work, I suggest you try to return the remote and buy and harmony remote. For me it worked very well with everything including old audio amps and you can configure your own activities.
Oct 20, 2012 | Bose Cinemate Digital Home Theater System...
Can't find remote for Bose Cinemate...is there any other way to turn it on without remote?
No, you need some sort of remote. Luckily this Bose uses IR for the remote and not RF. This means you might find a cheap universal remote that has a code for this. PC programmable remotes such as Logitech's Harmony, URC, and RTI remotes would definitely work.
If this was helpful, please rate!
Apr 07, 2011 | Bose Cinemate Digital Home Theater System...
Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Sep 07, 2009 | Bose 3 2 1 GSX System
My lifestyle12 remotecontrol stoped working
You can purchase a replacement remote from one of the sellers below, or use an universal remote.
You may need to find codes with auto detect if using an universal remote.
Replacement Remotes
1-800-Remotes
TV VCR DVD Stereo Remote
Best Replacement Remotes
Remote Controls Incorporated
123 Remotes Replacement Remote Controls
Mar 21, 2009 | Bose Lifestyle 12 System
Need Universal Remote Code for Panasonic DVD Home Theater Sound System
Need a remote for a Bose CINEMATE Digital Home Theater Speaker System. Where can I find one?
Dec 26, 2007 | Bose Cinemate Digital Home Theater System...
Need a universal remote control code for sony dav-dz 100
use kameleon urc remote there are a list of codes in back of manual one of the sony codes will work
Oct 17, 2007 | Sony DAV-DZ100 System
29 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
