Shopping cart, golf cart, motorcycle, limosuine, tank, 2 wheel, 4 wheel, rear or front wheel drive? Slow speed, all speed, worse when faster or go away? Squeak could be anything from hubcap to wheel bearing, wear indicator on brake pad. bearings typically dont squeak they roar and get worse at faster speed
It could be a number of things. First check your brakes for any rocks or excessive dirt. Second, check to make sure you are not in need of new brake pads. Brake pads are equipped with a tab that starts making noise when its time to replace your brakes. Third, have the bearing checked. Once the bearing get excessively worn they will start making a squeaky sound. Also have the shocks checked. the bushing worn out in shocks can also cause the noise. The best bet is to have your local mechanic inspect your front end for any wear. Once he does this, he can compile a list of parts that need replaced. Then you can replace or fix it yourself.
Generally, trucks, vans and large cars with big engines will have rear-wheel drive. Smaller, economy and compact cars are most often front-wheel drive. But you don't have to guess which one you have - find out for yourself.
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
Instructions
Understand that front-wheel drive means the power from the engine and the transmission goes to the front wheels; rear-wheel drive means the power goes to the rear wheels. Four-wheel, or all-wheel, drive means all four wheels are powered.
Open the hood.
Find the front of the engine. The front of the engine is always where the belts are located.
Look to see if the front of the engine is by the fender (side of the car). If so, then you have front-wheel drive.
Check to see if the front of the engine is by the radiator and the grill (front of the car). If so, then you have rear-wheel drive.
Look under the car near each front wheel. If you see an axle with a rubber boot (called the CV boot) on either end going into the wheel, then you have front- wheel drive.
Look under the car between the rear wheels. If you see a large, metal, pumpkin- shaped thing (it's called the differential) with two axles coming out either side, then you have rear-wheel drive.
Check both under the hood for the position of the engine and under the car for the axles to be sure, because not every car follows the rules for engine position and front- or rear-wheel drive (see Tips below for examples of cars with variations on this rule).
