Question about Photography
Why does my 7" Pandigital picture frame cut off on its own?
My Pandigital picture frame will cut off after showing one or two pictures and will not come back on until I unplug the transformer and plug it back in.
5 Suggested Answers
Anonymous
  • 6 Answers
SOURCE: Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Posted on Dec 11, 2008
Anonymous
  • 5 Answers
SOURCE: Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Posted on Dec 20, 2008
Anonymous
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Posted on Feb 11, 2009
Anonymous
SOURCE: GE 27956 only produces white screen in photo frame.
I followed these steps that were listed, but it didn't work. Then I increased the time in step to an hour, and it worked
I called GE support. I was told
1. unplug power from base
2. unplug phone connection from base
3. remove cover and battery from handset
4. wait 10 minutes
5. put battery back, reattach phone connection and power
It solved the problem.
Posted on Jul 21, 2009
Anonymous
SOURCE: Trying to move photos from Apple Mac to Pandigital frame
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
Posted on Dec 28, 2009
How do you load pictures on a pandigital picture
Hello there,
The Pandigital picture frame saves its image files on the memory card. You can put pictures in memory card by inserting it to a memory card reader on the computer and copying pictures to it. Tthe picture frame, then reads the files on the memory card.
Should you need further assistance, please let me know. Thank you for using FixYa.
Aug 07, 2011 | PANDIGITAL (DPF802) Digital Picture Frame
My Pandigital EReader is frozen, it won't even go into sleep mode.
My pandigital has been frozen on the pandigital novel options for 1 full day. How can i shut it down and read the books I have?
Jan 06, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
How do i upload pics from my pc
I have a Mac and tried to drag and drop my photos as mentioned above. The results?
- Wiped all pictures off of the frame.
- When I tried to reload from my laptop it shows "format not supported" as a placeholder for the pictures. The images are in jpg format.
How can I fix this problem?
Mar 18, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Pictures are cut off! Just got a 8 inch Pandigital photo frame for Christmas and loaded pictures on it. Since it does not have auto-rotation, I manually rotated any pictures that needed it before I put...
The frame is cropping the images to fill the screen. You need to change the image display settings from Optimal to Original in the setup menu. This way the entire image will show.
Dec 30, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
My pandigital frame is only letting me load 85 pictures
How big our your jpg pic files?
reduce them to 800x600: sh hold about 200+ pics.
also delete the pics that were pre-loaded
fred
Dec 18, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Unable to bring up the setup screen for display option
can't get the frame to cut off and start back up to show the setup program
Apr 02, 2009 | PANDIGITAL PAN80-2 (892235000548) Digital...
My pandigital photo frame is frozen on the sytem start screen
Mine does this when the power cord shorts itself out. For a whileI could fix it by simply untwisting the cord close to the plug, but eventually I had to cut and splice the cord to keep the lines separate (think a bunch of electrical tape. It works fine now that the cord isn't shorting out. Hope this helps!
Feb 02, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Inserted camera memory card into pandigital picture frame and all I get is the canned slide show; not my pictures.
Try another memory card. Sometimes one memory card will work and not another. They really dont support cards larger than 1 GB in size.
Nov 30, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Photography Logo
219 people viewed this question
Top Photography Experts
Ekse
Marvin
Marvin
Are you a Photography Expert? Answer questions, earn points and help others
