SOURCE: i have a sanyo aircon split system and i need to know the icons
the icons are snowflake = cool, raindrop = de humidification, fan blade = fan, sun = heat. hope this helps.
SOURCE: drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
SOURCE: the cooling unit outside is not working
your compressor may have seized up or burned up or blew a fuse. you may want to call an ac tech cause you cant really do much yourself with it. if the compressor is seized you may be able to unstick it by taking the back off the ac unit and hitting the compressor which is the black thing. dont hit it to hard just give it a few firm hits all around with something like a rubber hammer or something else like it. if this doesnt work it may have burned up or you may have blown a fuse. the lights flash probley because the unit is trying to tell you something is wrong with it and the way it flashes may be a error code for a tech. hope this helps.
SOURCE: i have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
