Question about BenQ Cameras
I have power issue with my Benq DC C1450, it kept asking to replace battery eventhough the batteries are newly bought
Posted by Gonzalo Afable on
5 Related Answers
Jane Deaux
  • 6 Answers
SOURCE: program
On Simon panels, the master code should default to 1234 if it's been powered down for several hours (I can't remember how long, at least four hours, possibly 12-16). So, unplug it from the wall and disconnect the system battery and leave it for the night. Power it up by plugging in the battery first and plug it into the wall. Then enter the code as 1234. It should annouce that the alarm system is disarmed. If so, your code is 1234. ;)
When removing the battery, be very careful to not break the little tab that holds it shut! Can't stress that enough.
Posted on Nov 20, 2008
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: where can i find benq lithiumion battery pa pack 3.7V 650mAH
go to this site to buy one
http://www.google.com/products?hl=en&q=benq+DC+C500+battery&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
Posted on Dec 16, 2008
IQUIT
  • 3940 Answers
SOURCE: Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Posted on Apr 26, 2009
damien729
Damien Gole
  • 221 Answers
SOURCE: Battery won't charge. Replaced battery, charger and DC Input board
Please check this article at apple support:
http://www.apple.com/support/macbook_macbookpro/batteryupdate/
Thanks Damien
Posted on May 29, 2009
Anonymous
SOURCE: DC E600 battery problem
I think the problem is you do not use the battery in the correct position! You should look at the signs + to + and - to - !!!
If you insert it in the inverse position the battery quickly discharges in seconds or few minutes.
Posted on Mar 08, 2010
My camera just stopped working. when i turn it on the lense open slightly and the lense wont come out as usual and the light shows for 5 seconds blinking then goes off. the model of my camera is a BENQ DC...
Your batteries have worn out. They don't give enough power for the camera to switch on properly.
Replace the batteries. Use 1000mAh or better batteries.
Aug 21, 2011 | BenQ DC X610 Digital Camera
Ok,please,help!I've just bought a BenQ DC C1450 digital camera in black which came without an SD card,but I had two of them at home.So I came home and put in one,but when I turned on the camera it said...
Make sure the card is not locked. Move the slide switch on the side of the card back and forth a couple of times ending with unlocked. Let me know the results.
Apr 22, 2011 | BenQ Cameras
I want guide to set hd video on my benq dc c1450
You need SDHC card or higher up to 32 G
Dec 16, 2010 | BenQ Cameras
Apr 20, 2008 | BenQ DC E600 Digital Camera
Advent camera battery charger
Here's a list of cameras that use the same battery.
ADVENT:
ADV1172E
BENQ: BENQ:
DC C500, DC E43, DC E53, DC E63+, DC E720 DC C500, DC E43, E53 DC, DC E63 +, DC E720
KONICA MINOLTA: KONICA MINOLTA:
DiMAGE E40, DiMAGE E50 DiMAGE E40, E50 DiMAGE
PREMIER: PREMIER:
DS-4331, DS-4346, DS-5330, DS-5341, DS-6330, SL-6, SL-63 DS-4331, the DS-4346, the DS-5330, the DS-5341, the DS-6330, SL-6, SL-63
ROLLEI: ROLLEI:
Prego DP4200, Prego DP5200, Prego DP6200 Prego DP4200, Prego DP5200, Prego DP6200
Hopefully this will broaden your options when searching for a compatable charger.
Mar 23, 2008 | Cameras
The camera does not come on
take it to the after sales service, they would probably be able to help u fix it. Can u suggest a link where i can download the software for BENQ DC C500? i want to use it as a webcam. thanks
Aug 29, 2006 | BenQ DC C500 Digital Camera
Cameras Logo
81 people viewed this question
Top BenQ Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
ChinthakaJ
ChinthakaJ
Are you a BenQ Camera Expert? Answer questions, earn points and help others
