Computers & Internet Logo
Question about NEC Computers & Internet
I have a NEC Multisync p462 lcd display monitor... I need to know how to display the monitor in portrait format (monitor on its side)
Posted by Timothy Law on
FastHarley
  • 761 Answers
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
Posted on Mar 15, 2019
Joshua Sulwer
    Habit-Forming:
  • 101 Answers
What is it hooked up to? If a windows computer you can quickly do this by holding down 3 keys at once. Ctrl + Alt + choose an arrow key. Tip if your doing this on dual display, what ever screen your mouse last clicked on will be changed when you do this. Ctrl + Alt + left arrow or right arrow depending on orientation desired.
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: Power on Green but no display (blank screen)
In the LCD1830 the inverter for the backlight always burns out. They are fairly easy to replace when you remove the back to get inside. A new one is available from MoniServ for $69.99. http://www.lcdpart.com/Products/uhp061104mss.html
Posted on Apr 07, 2007
informatica
Greg Cann
  • 1114 Answers
SOURCE: mounting a NEC MultiSync LCD 1560
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 22, 2007
Anonymous
SOURCE: touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
Posted on Jul 04, 2009
Anonymous
SOURCE: NEC MultiSync LCD 1560V+ 15 '' LCD Monitor touch-screen
How do you flip the screen on this lcd computer so it's side ways
Posted on Feb 16, 2010
Anonymous
SOURCE: screen and colors too bright
Sorry to say, but I'm having the same problem. If it doesn't change when you press the Fn key and the hollow/right arrow sunshine, then, I doubt there's anything you can do.
Posted on Feb 18, 2011
2answers
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
NEC P462 won't turn on
Look for loose contacts in power outlet, RC Jacks, sockets, cables.
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
The resolution notifier keeps popping up (NEC multisync 1740 CX) and I am unable to turn it off.
It probably is warning you that your video graphics adapator is puting out a non-native resolution to the monitor.
LCD monitors are designed for a specific resolution. If you don't use that resolution, the LCD has to try to mimick the resolution you've asked for.
Check your display settings and also consider updating your graphic driver if a new version is available.
Hi I just bought 7 NEC Multisync LCD1550v monitors and they all have the same problem. when plugged in all i get is a blinking power light. 1 of them showed signs of life for just a second but that was it....
You buy a new LCD Monitors, now still not working., if that new LCD Monitor is OK, then check your VGA Card, its inside the CPU maybe its broke or not connect properly inside. This are the cause of not displaying in your LCD Monitors.
If you here some beeps of your CPU then find out how many beeps and tell us here immediately.
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
[email protected]
1helpful
Touch system not working NEC multisync 1550v
2helpful
2answers
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
David Shaub
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
