Question about Makita Drills
How to replace the pulley on the Makita 9901?
Posted by Jeremy on
Makita 9901 belt sander. How to separate the shell halves so I can replace the cord? I’ve got all the possible obvious bolts removed but something else is holding it. Hidden bolt, clips???
Have a close look for plugs covering hidden screws. Most power tools now have security screws in them to stop people opening them up. You may need to buy a set of special screwdriver bits to get these out.
Sep 30, 2018 | Makita Tools & Hardware - Others
Imperial golden harvest juicer #9901 replacement parts I need new base mounts for stainless part to white enamel base
Fixya is unable to suggest sources for Imperial golden harvest juicer #9901 replacement parts.
Aug 28, 2018 | Juicers
Kenmore 9901 dryer - heating element burned, fuses are OK. How to replace the heating element?
FIRST-DISCONNECT THE ELECTRIC SUPPLY.
Go in through the back. Disconnect the wires going to the heater chamber. Remove the 3 or 4 screws holding the chamber in place. Remove the chamber. Remove the 4 screws holding the element assembly in place. Replace the element and put everything back into place.
Dec 19, 2012 | Kenmore Dryers
How do I change the belt on my Makita 2012 Planer
Probably not the proper way but it works. Assuming you have removed the side cover and the brace and are looking at the drive belt. I put my machine on its end so I was looking down on the belt. I put my belt on the first 2 groves of the small pulley and started the belt on the larger pulley (it will only go on about 1/3) using your allen wrench turn the large pulley clockwise while not letting the belt slip off the top. Now your belt should be started on both pulleys. From there it's a simple matter of walking the belt on one or two groves at a time by pushing down on the belt as it enters the pulley. Do one pulley then the other until it's completely seated in all groves.
Dec 31, 2010 | Makita 2012NB Electric Planers
My Makita 9901 belt sander is used but very slightly and now is just frustrating to even use. What is the most common cause for tensioning roller to keep pulling the sanding belt over against the housing?...
There is a screw that changes the angle of the roller to change the tracking of the belt... this is very sensitive and probably if you are having trouble is more a reflection of the belt quality then the sander...try different belts before you toss the sander... I have had one for years and love it... although the belt tracking is tricky sometimes anss your have to keep after it...
The adjust ment is very touchy only turn it maybe 1/8 turn at a time...
heatman101
Aug 31, 2010 | Makita Tools & Hardware - Others
Makita 9901--How to remove and replace motor bearings
Do you have a bearing splitter? If so I have used one and then gently tapped the end of the shaft to remove the bearing. The rubber pins fit into holes next to the bearing bore in the housing. You can use a vise and a soft hammer to tap the bearings on. Put the bearing on the vise and tap the opposite end of the shaft. You are on the right track for all these methods.
Nov 13, 2009 | Makita 9901 3 inch x 21 inch Belt Sander...
How do you install drive belt on makita model 2012 planer
you roll it on, start belt on bigger pulley and then just turn pulley by hand and gently start it onto the smaller one. UNPLUG tool first though
Sep 19, 2009 | Makita Tools & Hardware - Others
Tool is cracked, is it PVC or another type of plastic
I dont know what kind of plastic these sanders are made of. Your best bet is just to try a strong 2 part epoxy. If the epoxy doesn't bond then you should be able to just scrape the glue off and try something else.
Oct 22, 2008 | Makita 9901 3 inch x 21 inch Belt Sander...
Drills Logo
264 people viewed this question
Top Makita Drills Experts
efs_perpends
efs_perpends
John Trevino
epangan29
Are you a Makita Drill Expert? Answer questions, earn points and help others
