Question about Ricoh Office Equipment & Supplies
MY RICOH SP 111SU PRINTET SHOW THE ERROR C6 WHATS THAT MEAN AND HOW REMOVE ERTOR IN MY PRINTER SIR PLEASE HELP ME
Posted by SAIFI PAN on
5 Related Answers
Anonymous
  • 37 Answers
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Posted on Nov 16, 2007
Anonymous
  • 87 Answers
SOURCE: RICOH AFICIO SP C411 DN COLOUR LASER PRINTER
Open the side cover, and unlatch the plate. The PCUs are located in there. In the replacement PCU, there should be instructions.
Posted on Apr 01, 2008
Anonymous
  • 10 Answers
SOURCE: ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Posted on Nov 05, 2008
Joseph Micallef
  • 86 Answers
SOURCE: My Rico Aficio 200
Please open the front door and turn the blue lever in the middle,
remove the Transfer and Separation unit and check if the bushings of the transfer roller are damaged.
If OK, please give some oil on the shaft/bushings of the transfer roller. This unit may be replaced as a whole unit.
If SC401 re-occurs, please check the Photoconductor unit (drum).
Posted on Jan 13, 2009
Joseph Micallef
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
Ricoh SG 3100DN error code SC 28211, what is that and how do I repair?
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/96767-ricoh-sg-3110sfnw-showing-sc28211-error-code.html
Did not report a solution, but quoting from link above:
Ricoh Sg 3110sfnw showing SC28211 error code
Ricoh sg3110 sfnw showing sc28211 error code.
In trying to Execute carriage change sp mode (3-009-002), I cannot find 'Engine setting' (which according to the service manual) supposed to be under 'Printer setting' menu from Service mode.
Can someone help on step-by-step procedure of getting to the "Engine Setting" (sp mode) menu please in case am omitting something along the line or is their a permission required?
Dec 21, 2017 | Ricoh Office Equipment & Supplies
Error code sc364 I have exactly the same problem Ricoh no help wat so ever. Now have a heavy paper weight!
there is no specific error code decoding for this error sir.
this must be as service error.
please refer to a service manual for decoding this error.
Aug 08, 2008 | Ricoh Aficio SP C411DN Laser Printer
Ricoh aficio sp 100su has error code c6
SC101 c6 C CIS Lamp/Scanner Motor Error A problem occurred with the CIS or scanner motor in the flatbed scanner: -Carl
Nov 13, 2014 | Ricoh Aficio SP 100SU e Laser...
How to solution of FUSER TEMP.
my rocoh printer SP 100su show on lcd panal C8 error code . power on .
May 17, 2012 | Ricoh Aficio Sp 1000sf All-In-One Laser...
Hi, I have a Printer Aficio SP 6330N and it show an error sc542 service call in the menu screen, can you help me please? Regards
This error code means temperature fusing problem. Check all of the connectors on the fuser connector and receptacle, just to make sure that full contact is being made.According to Ricoh direct techs after 100K to 200K copies on a new machine the Hot Roller would start to warp (ever so slightly) because of its thin wall construction (fast warmup time).Replacing the Hot Roller will solve the problem.Please don't forget to rate me if satisfied.
Jun 07, 2011 | Ricoh SP 6330N AllInOne Laser Printer
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Apr 29, 2010 | Ricoh Aficio SP C811DN Laser Printer
Copier code error
service program sp-9, mode 90 needs to be set to "0"(off). also, the key counter shorting connector must be removed.
that should disable any key counters.
Mar 29, 2009 | Ricoh Office Equipment & Supplies
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
340 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
