Question about Thermador Refrigerators
Our 48" Thermador freezer/refrigerator started frosting at the top of the freezer. It is over 5 years old. After replacing the rubber liner to the door it still didn't fix it. Is there a fix ?
It is frosting at what is a seam in the lining of freezer and tech says it can't be fixed. Thermador is offering 50% off a replacement unit. Is there a fix for this?
Posted by blaine burgan on
Chris Huff
    Top Expert:
  • Thermador Master
  • 6,289 Answers
Get a second opinion, but I would say thermador must think he’s right or they wouldn’t offer the 50% off.
Posted on Dec 04, 2018
4 Related Answers
Anonymous
  • 828 Answers
SOURCE: motor runs, some ice at top level, but temp is at 50-60 degrees.
Defrost the freezer. Door being ajar allows moisture to build on the freezer coil and stops air circulation. In frost free units this condition should clear itself after about 8-12 hours max. Locating and advancing the timer by rotating the clutch head screw clockwise slowly until you hear one click. This will start the automatic defrost manually.
Posted on May 19, 2008
Anonymous
  • 700 Answers
SOURCE: Frost problems on the two top drawers of the freezer
you can manually defrost the unit with a shop vac that has a attachment that will direct the outlet air to the problem but that is just a temporary fix, the main problem is that moist air is getting into the freezer either from the gasket or somewhere else. Try the dollar bill test on the gasket to see if its bad. This is how to do it,you take and put the money between the gasket and the refrigerator and close the door. If you can pull out the dollar real easy the it's time to replace the gaskets. if there's resistance from the gasket then they are ok. From there you can decide if you want to call out a service tech or attempt the repair your self. Thank you for using FixYa.
Posted on Dec 25, 2008
Anonymous
  • 2468 Answers
SOURCE: no cold air in the refrigerator or freezer in top
replace the ptc overload on the compressor,they just unplug off the compressor after removing the spring clip that secures it to the compressor
Posted on May 24, 2010
Anonymous
  • 2341 Answers
SOURCE: Amana tr25s5w top freezer refrigerator.
Their are a couple possibilities;
The door gasket was letting air into the freezer and the resuliting warm air will condensate and freeze and the resulting ice of the condensation has froze at the vents where the cool air enters and or returns from/into the fresh food compartment. the vents can be seen in the ceiling of the fresh food section and you would see ice build up in them. If thats the case turn off the entire unit and use a hair blow dryer to thaw and remove that icebuild up freeing the vents for proper air flow.
Secondly it could be a defrost problem BUT the vents are clear but the coil in the freezer is still blocked with frost,once again blocking proper air flow into the fresh food section. If the coil on back wall has frost on it but NOT between all spaces its the vents. IF entire freezer coil is blocked with frost and you cant see between the open spaces on the coil in freezer its a defrost problem.
Heres what to check if entire coil in freezer is on big frost block;
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST CONTROL...it is hard to check for a semi unskilled person and if the heater or defrost t-stat check good its going to be the problem. It will NOT be in the freezer it could be on back wall or inside the control panel in the refrigerator section.
Good luck,
Gene
oldtech2332_9.jpgoldtech2332_10.jpg-->
While these pictures are for a different brand ALL refrigerators are similar and may look some what different than your but will be similar enough to yours
Posted on Aug 16, 2011
My refrigerator developed a chemical smell, more profound in the freezer. It caused the ice to have a chemical taste in them. The refrigerator is about 8 years old but used only about 5-6 years. Frigidaire...
In the freezer behind the false wall is an evaporator, surrounding this is a heater for defrost purposes. While inspecting this, look to see if the heater has made contact with the liner in any way, it is possible but rare the cal-rod heater has changed shape and made contact with the liner. So when the heater comes on during defrost it melts the liner giving off a chemical/burnt plastic smell. Best repair in this problem is to move or relocate the heater away from the liner, seal the liner with silicon and tape (a nylon tape), be sure to clean the heater also to prevent more smells. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
1helpful
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
The display will stay on normal for about 5 min and then give me a Er FF. What to do?
problem may be the main pcb or evaporator fan motor. this unit has several problems. if the model# starts with a 795 it was made by LG. the er ff code is caused most of the time from frost building up around fan motor. this can also be caused by freezer liner sagging at the top of freezer causing frost build up, sears has a service flash for this that is covered by the manufacture. service flash sf46-512. iwould call sears and find out if your model is on this service flash.
2answers
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
1helpful
2answers
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Refigerator leaked water slightly then stoped cooling
Yes try to turn with a screw driver if possible. If it start working replace timer. If not it can be low on freon you would see frosting but no cooling.
3answers
New Refrigerator Past Warantee Not staying cold
is the fan in the freezer running? if not then the air cant circulate and nothing will cool properly. if is running, is there frost build up on the inside back wall of the freezer? if so you have a defrost problem. if no frost on the back and the fan is running, remove the back panel inside the freezer and make sure all of the silver coils have light frost on them. if only part of them are frosted get out your manual and look at the warranty section. then seal system may have a 5 year warranty. if it does then call sear for warranty service. if the coils only have partial frost and its not under a 5 year warranty buy a new frig. because repair will cost more than its worth
Refrigerators Logo
Top Thermador Refrigerators Experts
Ekse
ray gallant
Tom Chichester
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
