Question about FoodSaver Kitchen Appliances - Others
My Foodsaver V2440 auto seal does not work. - FoodSaver Kitchen Appliances - Others
Posted by Russell McKinney on
3 Related Answers
Anonymous
SOURCE: foodsaver compact vac 550 sealing strip doesn't seal
My machine stopped working because the sealing ribbon was broken and the tape was worn. FoodSaver no longer does repairs. I knew the wire was called nichcome ribbon so I searched that. I checked the resistance of the ribbon on my machine, it was about 3.8 ohms. I found a site called mpakonline.com and from their site I bought 1/16 x .005 nichrome ribbon and 3/8 x 5 MIL. x 18 YD Acrylic Teflon Tape. The total cost of these items was about $36.00, the ohm value of their ribbon was 1.66 somewhat less.I used ends from radio shack made the repair and it has been working fine for the last two months and I have enough material leftover for about ten more repairs.
Posted on Feb 20, 2009
Lee Eismann
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
kjhvbrether
Murray
SOURCE: Foodsaver V2440 won't vacuum air out
You need new replacement gasket, to get one, visit amazon FoodSaver Vacuum Sealer Upper Gasket Assembly T910 00075. I hope this was helpful. cheers foodsaver-v2440-vacuum-air-out-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Posted on Nov 25, 2014
Foodsaver V3835 seals but will not sufficiently vacuum.
Go on the Foodsaver website to get replacement foam rubber seals that contact the bag during the vacuum process.
Feb 17, 2017 | FoodSaver Kitchen Appliances - Others
Why is my Foodsaver V2440 motor noisy while vacuuming bags?
This is normal it means that its just pumping air out of the bag but if it gets too loud and its not pumping air out of the bag then you might need it looked at soon
Jul 12, 2014 | FoodSaver V2440 Advanced Design Vacuum...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
I have a Foodsaver 2840 that will vacuum and seal, but not seal alone. The manual button does not work (though it worked earlier today). I have tried everything. Any hints?
Hi donnaj615...
Start the vacuum and then immediately click on the seal button...
I have a 750 that does the same thing...
Please take time to rate me
Aug 13, 2011 | Tilia FoodSaver V2240
My sealing gasket is broken and it will not seal my food anymore. model 1050
Replacement parts for your product may be ordered online here:
http://www.foodsaver.com/Category.aspx?id=r
If you are unsure which gasket to order contact FoodSaver via their website:
https://secure.foodsaver.com/ContactUs.aspx
Feb 08, 2011 | Tilia FoodSaver V2240
Foodsaver V845 is not sealing? vacuums okay, but won't seal bag.
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Jan 24, 2011 | Tilia Foodsaver V835 Vacuum Sealer
Vacum works heatseal does not seal can i replace seal
Sealing always tends to be the problem with FoodSaver because during the course of normal wear and tear, the sealing strip and wire will naturally need to be replaced.
You can get replacement heating wires and strips at www.elementandteflon.com
We started out selling just replacement parts for heat impulse sealers but we kept on getting customer requests for FoodSaver parts so we've added that section to our website.
Dec 14, 2010 | Tilia Foodsaver V835 Vacuum Sealer
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
Jan 07, 2009 | Tilia FoodSaver V2240
Kitchen Appliances - Others Logo
73 people viewed this question
Top FoodSaver Kitchen Appliances - Others Experts
Marvin
Marvin
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
