Computers & Internet Logo
Masibulele Posted on Dec 04, 2018
Hey, was wondering how could I be able to use my OTG SanDisk duel 16Gb 3.0 USB drive on my Cellphone.... Mobicel V4
ROGBANMUN
Level 1:
Passionate:
Visited the website for 10 consecutive days.
  • Contributor 36 Answers
  • Posted on May 24, 2023
ROGBANMUN
Contributor
Level 1:
Passionate:
Answers
36
Questions
0
Helped
3273
Points
76
To use your SanDisk Dual USB Drive (OTG) on your Mobicel V4 smartphone, follow these steps:
1. Make sure your Mobicel V4 supports USB On-The-Go (OTG) functionality. Not all devices have this feature, so it's essential to verify its compatibility beforehand.
2. Connect the SanDisk Dual USB Drive to your Mobicel V4 using the micro-USB or USB Type-C connector (whichever is compatible with your phone's port).
3. Your Mobicel V4 should recognize the USB drive automatically and prompt you with a notification or a file manager app may open automatically. If nothing happens, proceed to the next step.
4. Go to the Google Play Store on your Mobicel V4 and search for a file manager app that supports OTG functionality. Some popular options include ES File Explorer, Solid Explorer, or Total Commander. Install the file manager app of your choice.
5. Launch the file manager app and navigate to the "Storage" or "External Devices" section. You should see the SanDisk Dual USB Drive listed there.
6. Tap on the USB drive's icon to access the files stored on it. From here, you can copy, paste, or manage files just like you would with any other file manager.
7. When you're finished using the USB drive, make sure to safely eject it from your Mobicel V4. This can typically be done through the file manager app or by going to the system settings and selecting the USB device to eject.
It's important to note that the specific steps may vary slightly depending on the file manager app and the Android version running on your Mobicel V4. However, these general instructions should help you connect and access files on your SanDisk Dual USB Drive using your smartphone's OTG functionality.
5 Related Answers
TimeDefensiv
Shahzad Waseem Akbar
  • 746 Answers
  • Posted on Jul 30, 2009
SOURCE: sandisk u3 cruzer micro usb device 16gb is not
My dear! first install software only without attaching USB when your USB required the software or driver then attach it or if your software does not required USB attach during installation, you have to attach it after the installing software. May it require reboot your system. Now your USB sandisk u3 cruzer micro device will work.
thank you
irishhitmen
  • 26 Answers
  • Posted on Sep 22, 2009
SOURCE: SanDisk microSDHC 16GB formatted to 1GB
place it back in computer, go to start/my computer right click your drive that contains the disk, select properties/format. format using the "fat" system and make sure you select the capacity in the drop down list to match your disc.
Anonymous
  • Posted on Jul 01, 2010
SOURCE: 16bg usb flash drive that only shows having 250mb of memory
right click ny computer click manage than go to disk management and click you ubs and delete the partition of you usb and repartition it. waring do not do any than to local disk (C:) in the partition
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Apr 21, 2012
SOURCE: where is sandisk servising center in guwahati
just take it back to the place of purchase im sure there will be some sort of assistance available it should be still under warranty
if you want you could have a look through all of you devices to make sure the all drivers are installed for these devices
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this post a reply
which country is Guwahati in
hope it helps
axn_almighty
Mrityunjay Naskar
  • 267 Answers
  • Posted on Jun 20, 2012
SOURCE: can a sandisk 16gb flash drive be repaired?
Try the flash drive in another computer, and if the problem is still there, the product may be corrupted.
If the product is still in it's warranty period, you should go to the manufacturer's service center, and they will replace it free of cost.
If the warranty period is over, just buy a new one.
Hope this helps, Mrityunjay.
I cant format my sandisk cruser 16 gb
Have you got an error message it gives you when trying?
If you have bought it new, then it could be a fake.
How can i put games into sandisk 16GB cruzer blade-USB flash driver?
You can copy games' setup files but to play them you should install them in your computer
How to format write protected SanDisk Blade Micro 16GB USB 2.0 Flash Drive?
i have SanDisk 16 GB Flash it's write protected kindly advice how to remove the write protected from my USB flash.
your kind advice will highly appreciate
I have cruzer 16gb i entered wrong password 3 times and it got locked i need access to data what do i do?
It doesn't look like this is possible. For your protection, SanDisk did not build in a backdoor or reset feature in the device.
Please see SanDisk's official statement on this feature:
http://kb.sandisk.com/app/answers/detail/a_id/191/~/u3-launchpad-password-feature
Sandisk cruzer 16gb, Macformat, tv won't recognize
Dowload codec Klite pack, via Google, and open the files with that media player, the tv should then pick it up, seeing as its a multi codec reader program, Hope it helps
Can't open my sandisk cruzer 16gb
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
Top SanDisk Computers & Internet Experts
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
