SOURCE: Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
SOURCE: JVC TV has flashing red
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
SOURCE: my panasonic th-50px60u television turned itself
Tries tv unplug,replug it back like about an hour later for the tv to do it resetting itself back to the factory setting,tv might work again.If not still same problems.The tv 90-95% it is the board that call the tv power supply board is having a problems.That the board where the tv power a/c cord plug into it.U have all tools and know basic electronic and also can do basic soldering works too?Yes,take the tv aparts,check the tv power supply board carefully for dying and soon to be dead capacitors components parts.These capacitors components parts are alway bulges up or puffing up onto it tops.These dying and soon to be dead capacitors components parts are bulges or puffing ups on to it tops must have to be replaced will solved ur tv power unstable and flashing red light.Or try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
