Question about Bulova Watches
I have a Bulova C9346002 watch that the second hand has stopped moving. i have replaced the battery and rest the watch but no luck. Any suggestions?
Posted by Michael Cerny on
5 Related Answers
Anonymous
SOURCE: watch casement cover replacement
looking for a battery cover to suit model D 377 tissot men's twotimer II vintage 1992.
Posted on Oct 20, 2008
Anonymous
  • 203 Answers
SOURCE: second hand moves every 4 seconds
the battery need replacing this is what its supposed to do when batt low. if this helps please rate joe
Posted on Nov 22, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: the second hand stop moving but the watch is still
The hands of an analog watch are often only press-fitted on the shafts (hour and minutes are tubular, seconds solid shaft) and the second hand has probably only slipped so it is no longer being driven. I suspect a watch-maker could reattach it for a small charge.
Posted on Sep 25, 2009
Anonymous
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Posted on Dec 11, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Posted on Feb 25, 2010
Testimonial: "I'm the one who submitted the question. Thank you, I will visit a watch repair shop. It's a shame the watch is only 2-3 months old! Thanks again "
How to set up second hand and chrono minutes for bulova 98B105 back to zero setting?
If you haven't got the user instructions you can get them via the following link:-http://www.bulova.com/watches/bulova/marine-star/98b105/
You should see "download user manual" at the bottom of the page.
Mar 31, 2011 | Bulova Marine Star Calendar #98B105 Watch...
Two years ago , I bought Bulova 26e10 men watch and yesterday it stopped moving . I noticed that it was slower than normal watch first of all and then it stopped moving when I let it alone 3 days....
Don't know what battery but a watchmaker will be able to help you for a very reasonable cost. He will also inspect the rest of your watch, case and band. Your watch will likely need the chronograph reset also.
Mar 28, 2011 | Accutron 26E10 Lucerne with Chronograph...
Brand New Watch second hand won't move. won't keep time.
The watch has a problem in the timing module and the second hand won't move (a cog wheel issue) this is clearly a manufacture defect that can not be remedied and should be returned since it is under warranty.
Feb 27, 2011 | Fossil Watch Style # ES2074
Bulova Marine Star with chronograph. The minute hand of the chronograph resets to the 'one minute' location, not the top of the dial. I tried pulling the dial out and pushing the 'A' button and let the...
I have the exact same issue with the minute hand resting at the 1 minute mark and now I have condensation under the glass. The watch is only 2 months old so I think I will return it.
Nov 14, 2010 | Bulova Chronograph Marine Star #96B99...
When I pull out the crown, I can move the hands but the second hand does not stop. How do I get the second hand to stop so that I can set the time to a time signal?
Most of the watches in their range have instructions on the details page.
I suggest you go to "http://www.bulova.com/", choose your area, click on one of the pictures to move onto the next page, then do a search on their range of watches.
When you find yours, click on its' picture and details of the watch will appear. You will find instructions there.
Mar 18, 2010 | Bulova Watch
Feb 25, 2010 | Bulova Diamond Chronograph #96R31 Watch...
Bulova Watch Millennia Motion 96B17 - stops - needs battery????
Dude, of course it stops during the night - it's a perpetual motion / kinetic watch. It doesn't have a conventional battery. When you move your arm (while wearing it), the natural motion of your arm will 'automagically' wind the watch. There's nothing wrong with it - these types of watches always have to be re-set in the morning if you don't wear it to bed (or you don't toss and turn in bed).
May 30, 2009 | Bulova Millennia World Time 98G66 Wrist...
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
How to align seconds hand for stopwatch feature?
If you pull out the crown to the 2ed postion the push the upper start button that should move the second hand up to zero then push crown in.
Jan 23, 2007 | Bulova Men's Black Leather, Black Dial...
Accutron Tahoe Chronograph
i have the same watch it needs a cleaning by a watch maker not jewler hope this helps
Nov 13, 2006 | Bulova Men's Accutron Tahoe Watch
Watches Logo
161 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
