You should turn off the remote emergency switch. Then check the reasons, but this is based on that you can not turn off the switch.
Electromagnetic valve for generator set shutdown is out of control.
Speed regulator of diesel engine has fault.
Operational errors may be that the control panel first breaks the key switch and then presses the stop button.
There are many reasons besides above reasons, you should check clearly and remove faults one by one, then will know what is the resaon.
We also supply Cummins diesel generator, if you need to have a new generator, please conatc us: [email protected].
SOURCE: 1999 DODGE CUMMINS SHUT DOWN FAULT CODES p1689, P1688
P-1689 NO COMMUNICATION BETWEEN ECM & INJECTION
PUMP MODULE
SOURCE: What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Problem solved by poster. good work!
250 kva DG showing fault code 1434 , please solutions
250 kva DG showing fault code 1434 please solution step by step.
