Question about Ricoh Office Equipment & Supplies
Ricoh Aficio SP C400dn show on screen please wait
How on screen please wait how can I remove it from a week now it refuses to print what should I do? please help
Posted by Lana Loka on
Waleed Ibraheem
    Habit-Forming:
    New Friend:
  • 65 Answers
HD could be defective .tyr disconnect
Posted on Jun 21, 2020
5 Related Answers
Anonymous
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
Anonymous
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
Anonymous
  • 29 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Posted on Aug 18, 2009
Ickoajnc
OfficeServiceAjnc
  • 211 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
dafonso
  • 24 Answers
SOURCE: I need to print the
From the manual:
"To Print configuration page, turn the printer off then while pressing and holding [the stop/start key] down, turn the printer back on, holding the key down until the READY indicator flashes once. The configuration page will then print out"
Posted on Feb 28, 2011
Testimonial: "Thank you. Could not find it on Ricoh's site."
4answers
My ricoh aficio is showing sc819
Bad hard drive? unplug it an turn on unit. -Carl
Aficio SP C410DN show "Please Wait"
what about the power is the power correct ?
2helpful
My new Ricoh C820DN printer gives me a "waiting
please DO NOT use PCL printer drivers. USE RPSC or PS (post script) drivers and everything will be OK
pifonski
WHAT OTHER RICOH PRINTER IS THIS COMPATIBLE WITH???
The Aficio SP C410DN is compatible with these other printer models:
- Aficio SP C411DN
- Aficio SP C400DN
It is also similar to the Aficio CL4000, but some of the parts may be different.
3helpful
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
1helpful
Ricoh Aficio SP C411DN printouts can be rubbed off of paper or lables
Fuser pressure roller is worn. Fuser is sold as part of the "maintenance kit"
5helpful
3answers
Toner Cart chip reset for Ricoh Aficeo sp c400dn
I believe you will need to purchase and install a reset chip. You can find them for the Ricoh C410 here at www.cfriends.com (that links straight tothe ricoh page - but if you need to search, type in "c410" into the search field on their site).
3answers
sounds to me you are using the "wrong driver" double check the driver and the OS you are using.
I would also turn the printer off and clear all print jobs from the print que and restart. After loading the new driver do a test page from the driver.
Open Questions:
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
