Question about Lowrance Boating
I have a Lowrance elite 5 dsi what settings should I run in deep salt water
Posted by Rose on
Charles Dana Stanley
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
For deep water you will want to run the lowest hertz setting. For example, if you have the option for 80hZ or 600hZ, then the 80hZ would be for deep water and the 600hZ would be for shallow water.
Posted on Oct 03, 2019
3 Related Answers
Anonymous
  • 491 Answers
SOURCE: My salt storage tank has water up over the salt
Not necessarily.....monitor the level....if continues to rise,then an adjustment may be required.....many salt tanks have water higher than the salt level at different levels as a normal condition.
Posted on Sep 08, 2009
mark Gianotto
  • 297 Answers
SOURCE: it keeps saying low salt i have an 18ft x 4ft deep
hello
there is too much for me to type please look up my name and posts about this issue
also look at my posts for low flow and green water
I promise you will learn very much about pool maitainence
Posted on Aug 08, 2010
zcomputerwiz
zcomputerwiz
  • 92 Answers
SOURCE: My lowrance elite 5 hdi won't go past the "elite
Make sure that your battery is fully charged. Try a hard reset if it still won't start up.
This will erase all user information on the device, so you will have to set it up again.
With the unit off, press and hold the zoom in (+) zoom out (-) and power buttons. Release the buttons when the map displays.
Article Details
Posted on Jul 19, 2014
The depth finder on my elite 5 Lowrance blinks if I go over 14 mph. And the screen gets very hot after a few minutes of run time?
Hey Robert,
the blinking is usually the result of the transducer losing contact with the water..
As far as the screen getting hot.. that is not good.. do you have this unit mounted in dash? It needs some ~cooling.. just some airflow..
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Aug 28, 2016 | Lowrance Elite 5 Color SonarGPS Combo
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
Nov 23, 2014 | Lowrance Elite5x Color Fish Finder 102001
How do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
Apr 13, 2013 | Lowrance Elite-5 DSI Color Combo...
Will the Lowrance Elite 5 DSI work with the PPP 181 Lowrance Ice Pack unit if not is there a ice pack that will ?
Contact the Lowrance company directly on the internet and check with their experts! Nautical equipment is very fussy about its compatabilities.
Dec 27, 2012 | GPS
Cant get the demo mode off my lowrance elite 5 dsi
go to menu click on system find simulator mode click off
Sep 21, 2012 | Lowrance Elite-5 DSI Color Combo...
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Apr 22, 2017 | Lowrance ELITE 5 GOLD COMBO
Boating Logo
313 people viewed this question
Top Lowrance Boating Experts
Mike
Marvin
Marvin
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
