Optics Logo
D
Dan Parkinson Posted on Dec 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Moisture in my Bushnell rangefinder
My almost new Bushnell rangefinder has moisture in it after I got rained on yesterday. Cannot even see light through the lens when looking at the sun. Any ideas on how to fix this?
  • Max Muller May 21, 2020
    how did you solve the problem?
  • Colin44
    Colin44 May 21, 2020
    It is annoying when water gets in one of your components and ruins everything. All scopes and rangefinders should be waterproof and nothing like that should ever happen. I hope you managed to fix yours, but it is better to use the best equipment possible. I never hunt without my hunting rangefinder that I bought on https://www.atncorp.com/range-finder because it is really easy to hunt with it. The model i use is ATN AUXILIARY BALLISTIC LASER 1500 and it is the best. It is waterproof and it is great to use with any scope, but amazing with ATN HD scopes. I have their scope and rangefinder and I never had any problems.
Peter Anderson
Level 2:
Habit-Forming:
New Friend:
  • Expert 29 Answers
  • Posted on Dec 07, 2018
Peter Anderson
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
29
Questions
Helped
6682
Points
123
I think you should contact manufacturer, or special service. I use ATN LaserBallistics 1500 and it is pro. Water proofed. Weight is good. Nice leather pouch and wrist strap. Long life. I found it here https://www.atncorp.com/range-finder
Chris Huff
Level 3:
Top Expert:
  • Master 6,289 Answers
  • Posted on Dec 03, 2018
Chris Huff
Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017345
Points
74913
Are they supposed to be waterproof? If so, return them.
5 Related Answers
Anonymous
  • 47 Answers
  • Posted on Mar 18, 2009
SOURCE: 4Runner headlight has moisture inside. Light works fine
yes. it should be a fairly easy job, just be careful when removing the glass, and make sure you get your headlight re-alligned when it is done, as it will fail its mot if not done.
hope that helps.
Mr Tech Geek
  • 133 Answers
  • Posted on Apr 10, 2009
SOURCE: apparent moisture inside my bushnell pinseeker 1500
If when you look through the eyepiece and see some lite yellowish, lite greenish, oily looking wiggles, (sometimes black) spots you have thermal burns on the LCD display. This happens when the eyepiece cap isn't used and sunlight damages the surface of the display. The unit was left pointing skyward for too long. Most players take off the cap and don't use it. Bad decision. Bushnell can repair but, about $80+shipping......4-6 weeks without unit
Anonymous
  • 99 Answers
  • Posted on Apr 11, 2009
SOURCE: Moisture in my 3x9 Bushnell Banner Scope
Note Here is Bushnells contact information if you would like to ask them for suggested methods
Note most scope manufacturers offer a mail in repair service, this has to be cheaper than discarding your scope and buying a new one :)
Brad
Mr Tech Geek
  • 133 Answers
  • Posted on Apr 24, 2009
SOURCE: Bushnell Pinseeker 1500 Laser Rangefinder
All these units need an alignment....Vibration and dropping are slow death to Pinseekers.
Anonymous
  • 3361 Answers
  • Posted on May 24, 2009
SOURCE: Maytag Neptune Gas Dryer MD-6 - Moisture Monitor not lighting
Remove the rear vent and run a load. If it dries correctly, repair the vent blockage.
If not, replace the gas valve coils.
I have moisture on the lens of my bushnell v2 range finder. How do I remove it?
Silica Gel packets. Put them in a warm oven, put them and rangefinder in a plastic box with lid for a couple of days.
I seem to have water or moisture inside my rangefinder. How can I get this fixed or cleaned?
I've dried out meters, etc. before by putting the tiem in a bag of uncooked rice overnight.
2001 2.0 Jetta idles violently ,check engine light on and blinks occassionally
Have vechicle code scan to see what causing check engine light to turn on.
Very wet rangefinder
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
The LOB keeps coming back up even after installing new battery
I would send this unit in for repair. contact bushnell customer service at 800-423-3537 option 1.
Apparent moisture inside my bushnell pinseeker 1500
2helpful
2answers
Bushnell yardage pro compact 600 does not give reaDING
The CPU board has failed. Bushnell will not have parts to repair it. They will offer you one at a discount. Call them at (800) 423-3537
Top Bushnell Optics Experts
ZJ Limited
ZJ Limited
Bill Eager
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
