Question about Kenwood Computers & Internet
Mobile network i deleted mobile network setting on kenwood dnn992
What do i type back in or where do i find
Posted by James Beaty on
How do I delete the current APN and add the correct one for straight talk?
OK first of all go to settings, more, mobile networks, access point names, then press menu, select new APN, type the name of your service provider followed internet e.g MTN INTERNET, type Internet at where the APN is and then press menu again and select save. you are done
Jul 18, 2014 | HTC Inspire 4G Smartphone
How can I delete a channel already programmed in my Kenwood TK-705D?
You would need to use programming software and cables to make this happen.
Jul 09, 2012 | Kenwood Tk-705d Tk-705dh-1 Mobile Radio...
Mobile network settings
Hi
To input settings/choose from presets...
Press Menu Button (The one with four small squares on it)Go through menu and tap "Settings"
Tap "Wireless and Networks"
Scroll to and tap "Mobile Networks"
Tap on "Access Point Names/APN's"
If your Network is not listed press
The Menu Button again (Four Small Squares)
and tap "New Apn"
You will obviously need the settings.
You can probably find these on your network providers website.
Most Service Providers offer a text setup service.
This will send a text message to your phone which you read and delete, then restart your phone and settings should be set up automatically.
Check your Networks website to see if this service is available.
I hope this helps!?!
Mar 10, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Nokia x3 - 02 "only 70 sets allowed setting
First you need to delete the previous configurations sent by other network or the configurations you don't use, because nokia mobiles are bounded to save only upto some numbers of networks configurations.
Oct 05, 2011 | Nokia X3 Touch and Type Cell Phone
All web pages not disp;aying
Make sure you have go the correct internet setting you will be able to obtain these for your network provider. Delet all history and cookies.If this dose not work speak to your network provider.
Hope this helps
Feb 11, 2011 | Motorola Mobility L9 Unlocked GSM Cell...
How do I connect my Kenwood VR-715 surround sound system, Dish Network receiver, and HD LCD TV together so the surround sound works? Can't figure out what goes in the input, the order of the connections or...
The best way to do this is to connect you dish network receiver is directly to the tv. Try to use the best video type possible. HDMI is the best, next is component and lastly is composite. This will take care of the video portion. Next, connect digital audio output to the Kenwood Receiver. I dont know what type of a digital audio output your dish box has, but your kenwood receiver has both optical and coaxial inputs so you should be fine there. Once you have both audio and video wired, change the inputs on both your tv and kenwood receiver to the inputs you are connected to. You might need to set up the kenwood to tell it that your running digital audio to it in the setup menus. Hopefully this helps, let me know if you need any clarification.
Good Luck
Jan 08, 2011 | Kenwood VR-715 Receiver
Y cant i send picture messages or recieve them either from my g1
You need to have the interent package to do that. If you dont there are some settings that can bypass that:
Menu > Setting > Wireless controls > Mobile networks > Access point names
Once you get in there, scroll down until you see T-Mobile US and input the following settings:
Name = T-Mobile US
APN = wap.voicestream.com
Proxy = 216.155.165.050
Port= 8080
Username= None
Password = None (delete the 4 digit PW that is there)
Server = Not set (also delete the 1 digit PW there)
MMSC = Unchanged (do not change it)
MMS proxy = 216.155.165.050
MMS port = 8080
MCC, MNC, and APN type all stay they was they are.
Now as far as remembering the old information goes, you can always go into T-Mobile US 160 (right below T-Mobile US), which has all the same settings as T-Mobile US including the password. All you have to do is copy and paste it.
TAAA DAAAA!!!!
May 13, 2009 | HTC G1 Smartphone
Internet and MMS settings for ATT carrier with unlocked samsung f-480
AT&T Settings
1) Start>Settings>Data Connections>Menu>Edit Connections
2) Open Dial-Up Connections. Delete all Orange Settings.
3) Open Proxy Connections. Delete all Orange Proxy Settings.
4) Create PROXY CONNECTION:
Description: mMode
Connects from: The Internet
Connects to: WAP network
Proxy (nametongue.gifort): 10.250.250.54:8080
Type: HTTP
Username: (blank)
Password: (blank)
5) Open GPRS Connections. Delete all Orange Settings.
6) Create a new GPRS CONNECTION
Description: ATT GPRS
Connects to: The Internet
Access point: proxy
User name: (blank)
Password: (blank)
Primary DNS: (blank...will later default to 0.0.0.0)
Secondary DNS: (blank...will later default to 0.0.0.0)
IP address: (blank)
7) DATA CONNECTIONS
Internet Connection: ATT GPRS
Work Connection: Automatic
WAP Connection: Automatic
Secure WAP Connection: Automatic
8.) In Internet Explorer, Menu>Options>Connections
Auto Detect Settings: Unchecked
Select Network: Wap Network
9) MMS SETUP.
Inbox>Menu>Options>Account Setup>MMS>Menu>Edit Connections.
Delete any Orange Settings that are there.
10) Menu>Add
Description: ATT MMS
MMSC Address: http://mmsc.mobile.attwireless.net
Data Connection: The Internet
Gateway: WAP 1.0 Gateway
IP Address: 10.250.250.100
Port: 9201
11) Click Done twice to return to the MMS Setup Screen
Server: ATT MMS
Download Messages: Automatically
Outgoing Message Size: Less than 100KB
Allowed Message Types: Personal
Click DONE.
Cingular Settings
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to [email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to [email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
May 02, 2009 | Cell Phones
No MORE TEXTING!!!
you need to have the phone reflash so take it to a mobile service center and have them reflash it for you.
Feb 20, 2008 | Motorola Mobility RAZR V3
Samsung D500
3 options.... 1) remove the sim, switch on the mobile and delete all contacts... if needed insert some unwanted sim... 2) download all the sim contacts manually somewere (using data cable)... and delete all contacts, thn upload the sim contacts... 3) call me -Cheers, Enz 9940092370
Jun 15, 2007 | Samsung SGH-D500 Cellular Phone
Computers & Internet Logo
60 people viewed this question
Top Kenwood Computers & Internet Experts
Mark Dischler
Mark Dischler
Level 1 Expert
Marvin
Marvin
Are you a Kenwood Computer and Internet Expert? Answer questions, earn points and help others
