Question about Brother HL 5170DN Laser Printer
Brother HL-5170 fuser reset
What is the procedure for resetting fuser life remaining after replacing the fuser assy??
  • Anonymous Mar 25, 2014
    fuser reset
Timothy Van Der Heyden
  • 152 Answers
Should be a service selection in the user tools/ menu. reset life/consumables/replacement etc.
Posted on Aug 05, 2009
How to reset fuser on my brother HL1870?
You can do whats called a Parts Life Reset Function.
This function is used by service specialists only when changing the periodic replacements parts to clear the life counter. To operate this function, press the "Go" and "+" switches together until the menu "RESET PARTS LIFE" appears on the LCD display. Select the required item "part name", using the "+/-" switches, then press the "Set" switch.
Your fuser error should now disappear.
Hope this helps!!!
Jul 19, 2011 | Brother HL 1870 Laser Printer
Help me with reset fuser problem on Brother HL-5270DN
HelloTo reset fuser on your HL-5270DN you have to press "Go" and "+" at exactly the same time. You will be given an extended reset menu. Then you will go for fuser reset.
Plz sure the fuser must be OK/replaced before applying this action
Good luck
Do rate the solution if got help
Dec 06, 2010 | Brother HL-5270DN Laser Printer
How do you reset the fuser count of a Brother HL4070CDW?
If reset parts is life not available after OK > Machine Info > Reset Parts Life (if it only shows "Parts Life", then do this:
Press GO and UP arrow at SAME TIME > Reset parts life
Scroll up or down to choose which part to reset
Press OK and confirm
Apr 14, 2010 | Brother HL-4070CDW Printer
How do you reset fuser life on a brother HL 4040cn
Press the Go and 'Up' buttons at the same time in the ready status.
The "Reset Parts Life" will appear on the LCD. Select the applicable periodical replacement part by pressing the 'Up' or 'Down' button and press the 'OK' button.
Mar 25, 2010 | Brother HL-4040CN Laser Printer
BROTHER HL-5170 FUSER COUNT RESET
To reset the drum you have to hold down the go button untill all the lights light up and flash.
Aug 05, 2009 | Brother HL 5170DN Laser Printer
How do I clean my Brother HL-5170 printer? It is
You may need a new drum, refilled and generic drums don't get a new cleaning blade and toner goes everywhere, some generic toners are not good as well. Also with age the fuser starts letting toner stick and transfer to your prints. As far as cleaning, you can take the supplies out and blow out the interior, may help for a while.
Jul 29, 2009 | Office Equipment & Supplies
Brother 1250. Message on screen shows - fuser malfunction. Alarm light flashes, no lights,followed by all lights
The Fuser is the part inside which gets hot. It will usually be a job for an engineer to replace, however it should try to reset by itself after 10 minutes with the power left on.
If not, switch off, hold down the button and switch on whilst holding the button. This will also reset, but if problem remains the Fuser unit will have to be replaced.
Jun 19, 2009 | Brother HL 1250 Laser Printer
Loud, knocking noises
your fuser is about to go...
happened to me last week
Sep 02, 2008 | Brother HL-5170 Laser Printer
RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
May 17, 2008 | Brother HL 5140 Laser Printer
Brother HL 5170DN Laser Printer Logo
1,831 people viewed this question
Norman  J Weimar Jr
Norman J Weimar Jr
k24674
