Question about GE Refrigerators
How to put freezer door back on GE profile side-by-side
Posted by Ellen Arnett on
5 Related Answers
lenwest
Len West
  • 150 Answers
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
Anonymous
  • 105 Answers
SOURCE: GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Posted on Apr 07, 2009
erpaalai
Eric Duda
  • 999 Answers
SOURCE: Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Posted on Jun 29, 2009
Anonymous
  • 153 Answers
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
Posted on Jul 21, 2009
Anonymous
  • 398 Answers
SOURCE: GE Profile Arctica freezer door not sealing properly.
Loosen the hinges on top of the door left side, . lift or lower the door till it is level with the top of the unit. now do the other door. now look at the line between both doors, and compare the gap at the top and bottom . adjust once more time if needed. clean the metal and the magnet with windex then put weson oil on a clean towel and wipe all the way around each door.. hope this was helpfull to you.... Sawdust46
Posted on Aug 11, 2009
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
GE Profile temperature going up and down
One of four problems,
1: this box has two sensors in the freezer... one on the top of the evap and one on the bottom left side of freezer cabinet (little small round white things) in the back lower portion of the freezer. These have been know to go bad and cause this problem.
2: you have a defrost problem caused by a bad main board or bad defrost heater.
3: you have a evap fan going bad on you, quits when frig gets to right temps. in other words the fan doesn't like the extreme colds,
4: door gaskets are leaking air around doors.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Mar 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
NO DRINKING WATER
common problem the water line inside the freezer door is frolzen up . to fix remove everthing from the freezer door , turn off freezer . open freezer door and put a blanket over the opening to the freezer leaveing the door to room temp for an hour or so to defrost . check if defrosted . remove blanket close door . this will happen with ge , try seyying the freezer control on the next lower number (warmer)
Jan 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge refrig
I have a ge profile side by side. when it auto defrosts the water runs to the bottom and out the freezer door instead of down the drian??
May 31, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Ron Rak
Ron Rak
gbob59
