Question about Dacor Ovens
I have a Dacor single wall oven. Lately it seems to be having issues when I choose baking it randomly switches over to broil. I was baking a cake the other day and when the cake was almost
Finished it switched over to broil and ruined the cake. I did open the door just before it switched over to broil. Can you help?
Posted by Kathy on
ch.vijaysagar
    Sergeant:
  • 272 Answers
5 Related Answers
Anonymous
  • 290 Answers
SOURCE: OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Posted on Nov 24, 2007
Anonymous
  • 33 Answers
SOURCE: Dacor Gas wall oven
is there tension on the door at the point where it doesnt seal,is the spring broken/missing,when the door opens and closes is there enough travel from point a to point b inside the cabinet on both sides of the hinge area, is the sping loaded mechanism damaged .
Posted on Dec 30, 2007
Anonymous
  • 31 Answers
SOURCE: Dacor double oven ecd230 -- bottom oven won't heat
check the ignitor.
Posted on Jun 22, 2010
Anonymous
SOURCE: Dacor Wall Oven won't heat - Cannot find thermal reset switch
Open the oven door and unscrew the vented panel at the top. Make sure the oven is off. Atop the electronics in there you'll see a little red button. Push it. Voila.
Posted on Jul 14, 2010
harrigan447
SOURCE: My Dacor wont heat, broil or convection after self cleaning
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Posted on Jan 10, 2011
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
CPS227W Dacor double wall oven from 1995. Problem is common to both upper and lower ovens on any cooking mode (broil, bake, etc). Turn on, set temperature, hear a relay click on, then about 15 seconds...
I have the same problem, however I found that if I just hold the Bake, Broil.ect button in until you hear the relay click then the oven functions normally.
Sep 26, 2009 | Ovens
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Dec 24, 2008 | Dacor MCS130 Millennia Electric Single...
How to find discontinued Dacor oven part?
Here's a link with a pdf file that lists your part #82810 for $202.31. http://ww1.dacorservice.com/PartsCatalog/docs/Links/2.pdf. The date on the pdf is 6/12/08. You can also locate a dealer or authorized service providor for Dacor applicances at: http://www.dacor.com/Customer-Care/Locate-A-Servicer.aspx. Good luck!
Jul 20, 2008 | Ovens
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
Jan 07, 2008 | Ovens
Convection Over with Dacor Millennia
We have the same issue anc alled Dacor. I seems as there is a problem with the oven as it was built with a faulty or missing temp control part. They have a fix for this problem by installing a temp control kit. you need to work through the warrantee group
Dec 20, 2007 | Dacor Millennia MOV130 Electric Single...
Ovens Logo
132 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Lollo Pop
Vincent G
Vincent G
Are you a Dacor Oven Expert? Answer questions, earn points and help others
