SOURCE: cant transfer limewire music from my computer to my mp3
The Limewire music is located in your My Computer> C:>Documents & Settings Folder>Administrators Documents (your name)>Shared Folder. You can manually drag these files from this folder onto your device, located under My Computer>Device Name (there may or may not be a music folder, you should put it in there if there is). Once you drag & drop the files, you should safely disconnect your device, then you are done. Best of Luck.
SOURCE: transfer music from limewire to mp3 player
heres what i did:
when u plug in your mp3 player, s screen should pop up click view files. when you download songs in limewire they should save in your documents so you pull your documents up and their should be a limewire file. go to the saved one. then transfer the songs saved to your mp3 player and it should work! worked for me :)
SOURCE: Need to download the Music Transfer Hard Disk Player Edition again.....
The software can be found here
http://rapidshare.com/files/131605546/aiwaplayer.rar.html
SOURCE: YP-T9J Screen stuck on transferring files do not disconnect
Vegggie Boy is mistaken. You should press and hold the red record button while pressing the menu button. The player will reset itself to normal operational mode.
SOURCE: album art does not transfer with music on my sandisk mp3 player
Go to the sytem Settings menu and go to this option:
Display Art in Lists
Enabling this feature displays a small image of the song album cover, audiobook
cover, and photos when scrolling through list of these items.
1. Scroll down to Display Art in Lists and select it.
2. Use thumbwheel to switch between On (enable) and Off (disable).
If changing this option to enable fials to resolve the issue, the solution is a bit painful: You will have to manually add the artwork to each single song within an album in Windows Media Player 11, delete the song that is missing the artwork off your sansa, and re-add the songs again after you are done manually ediitng the artwork.
Manually add album art (WMP 11)
1. Run WMP.
2. Click Library on the top bar.
3. Select and right-click the file(s) you wish to update and select Advanced Tag Editor.
4. Click the Picture tab, then click Add.
5. Navigate to the image you wish to use for album art then click Open.
6. Click Apply then OK.
