Televison & Video Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Removing a pedestal from plasma tv
I have a 50'' Panasonic plasma tv and can't figure out how to get the pedestal from the tv so I can mount it on a stand instead of the pedestal
Anonymous
Level 2:
  • Expert 66 Answers
  • Posted on Aug 04, 2009
Anonymous
Expert
Level 2:
Answers
66
Questions
0
Helped
24192
Points
164
If you check on the bottom of the pedestal there may be 4 screws inside the bottom to where once removed you might be able to slide off the pedestal
Separating a glass tv pedestal from a glass tv cabinet
I can only figure that the cabinet is Not part of the TV's normal design and it has been just sitting on this cabinet for a long while?
If this is so then it has by weight and heat sweated itself onto the top, synthetic feet are made of complex materials including oils which get exuded then form a quite powerful glue action, also that spray polish has baulking agents to make it look good in use these act as glue.
If this top is glass then its pretty well resistent to most things, try windolene glass spray its safe and dissolves many things on glass as a cleaner (or other surfaces). Move up to say WD40 a mineral oil again safe wipe clean with meths spirit to clean up just add in a bit of tilting to break that grip.
Hope this helps......
We have a wall-mounted Panasonic TH-42PX50U plasma that now needs to be placed on a table unit but the original pedestal stand has been discarded! Are those items available?
Hello
You can get a TV stand at any electronic store close to you or you can call panasonic and order for a TV stand directly from them
Where can i find a stand
If you're referring to the original pedestal base sold with the TV, your best bet would be Ebay
or Craigslist.
On Ebay, search in the Category: Electronics > A/V Accessories & Cables > Mounts & Brackets >
using the search string "vizio 50 pedestal stand" or "vizio pedestal stand base" and you should get a few matches. For example, this used pedestal stand, which has a current bid of $9.99 USD, or this new pedestal stand, being sold for $149.99 USD or Best Offer.
Hope this helps!
1helpful
2answers
I bought a used panasonic TH-50PZ85U plasma TV that was wall mounted. I need a pedestal base. Called Panasonic 3 days ago and the have to "research it". Can you help? km
My ex-husband threw away the pedestal stand for the Polaroid Polaroid FXM-3211C TV DVD Combo which I now have. I need a pedestal stand....do you know where I can find one?
We threw away the TV pedestal and used the wall mount, now we want to purchase another pedestal so we can use it for stand alone. Where can we find it? How much is it?
I might have one from a 42" maxent plasma that could fit on your plasma.
I will measure it and post the the dimentions if you're interested.
29helpful
3answers
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Need a pedestal stand for an AKAI 42" Plasma
do you have the small feet as shown in the picture? are they in your closet?
ebay?
2answers
Mounting TV
Assume you are mounting on the wall, if so a good mount will have the standard bolts in the package. If this is a used mount, you will need to determine the length based on the mount, the bolt size is either 1/4" or 5/16", probably the latter.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
