Question about Clothing Accessories
Any recommendations for homemade hat pins? - Clothing Accessories
Posted by HazelKlocko on
Cindy Dimaria Holbrook
    New Friend:
    Problem Solver:
  • 5 Answers
Where can I buy a hat pin holder for a good price?
Most hatpin holders are antique in style. Here is a site that sells antique reproductions of hat pin holders.
http://www.westernersoutfitter.com/900a/hat_pin_holders.htm
Mar 04, 2013 | Clothing Accessories
Tip
How to wear a hard hat properly
With so many different brand of hard hats there are all kinds of rules and for how a hard hat is meant to be worn. Never fear there are a few points that they all agree on and these are the ones that you should always keep in mind when you head off to work.
First you want to make sure that the suspension straps on the inside of the hat fit properly. You can adjust them by moving the pin to different holes much like you do to change a belt. The plastic of the hat isn't supposed to sit on your head like a regular hat. There has to be space between your head and the hat to help 'cusion' the impact of something hitting your head.
The ******** the back of the hat, one that sticks out lower should be tight on the nape of your neck. This strap helps in keeping the hat in place.
If your hard hat has a chin strap make sure that you have it adjusted properly because this will keep your hat on your head when bending over or looking up. The chin stap should sit on your chin suggly and not be looped under your chin in the space between your chin and your neck.
If you are finding it difficult to get the hat to fit properly never use fillers to make it fit better. You might just have a hat thats not the right size for your head. Using a filler can change the effectiveness of the hat and make it dangerous to use. Its better to ask for a new one then find your own solution.
on Nov 21, 2013 | Work Safety
What is a hat pin holder? My mum asked me to buy her one but I have no clue what it is.
A hat pin holder is a container, that traditionally was made from porcelain that has lots of holes (bigger than salt and pepper pot holes), in the top. You can use it to store hat pins which usually are very sharp at one end. This is a clever way of keeping them upright and in good condition.
I want to make my own hat pins, Does anyone know how?
First you need to buy a hat pin and the beads that you want to use in your hat pin. Decide what order you want them to appear and thread them onto the hat pin. Then use a crimping bead to hold all the other beads in place and use pliers to tighten it so nothing will fall off.
It's really as simple as that and if you bulk buy the hat pins, it can be a really cost effective way to match the pins to your clothing.
How do I accessorize a hat without making it look like a fancy dress item?
The secret when accessorizing a hat is not to over accessorize it. Pick a style and stick to it. You can use hat pins, scarves, a broach or a belt or even flowers and a feather. Just don't mix and match too many different ideas.
I have the new iphone 3gs. It currently does not bluetooh pictures/homemade ringtones. Any help?
The procedure for sending the data via BT is hat you make your device and the receiving device visible. Pair with the receiving device by clicking on it. Give the same password to both devices when asked for. Authorise the receiving device. Then you can send as much data as you want.
Aug 03, 2009 | Apple iPhone 3GS Black (16 GB)
Resetting Pin on Blue Hat ATM machine
Hi abbeybath,
We have the same atm/bank for our son. Here's the fix:
1 - push the reset button on the back of the ATM near the battery compartment.
2 - insert the ATM card and press the BALANCE button to change the user name (need to do this before getting to the pin)
3 - enter your childs name and push enter when complete. Cancel will delete an incorrect letter.
4- enter the default pin (1234) - this will bring up the DEPOSIT, WITHDRAWL, BALANCE screen.
5 - Press ENTER and it will show the current/default pin. Input the new pin number you desire and press ENTER again.
All set. Hope this helps!!
Jan 17, 2009 | Blue Microphones Blue Hat Little Shots...
Blue Hat Bank
Type in the code 1234 ENTER then enter your child's new pin.
Pax, Moncia
Jan 04, 2009 | Blue Microphones Blue Hat Little Shots...
Clothing Accessories Logo
254 people viewed this question
Top Clothing Accessories Experts
Jim Pattison
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
