Tablets & eReaders Logo
Question about Acer Tablets & eReaders
Reset acer tablet erasing robot keeps popping up
Posted by June Kondal on
1 Related Answer
buda2832
buda2832
  • 59 Answers
SOURCE: MY VISUAL LAND CONNECT 9 TABLET IS FROZEN. I CAN GET IT TO THE DEAD ROBOT BUT IT WON'T GOT TO THE CHOICES TO RESET
Press up and down volume buttons at the same time and the options should show up.
Posted on Sep 18, 2014
Testimonial: "Still did not work. Any other suggestions? Please and Thank you for your help."
Hard reset for my tablet allwinner A100
How to hard reset an allwinner A100 tablet If you're having problems with your Allwinner A100 tablet, you may need to perform a hard reset.
This will restore the tablet to its factory default settings and erase all your personal data. Here's how to hard reset an Allwinner A100 tablet:
1. Turn off the tablet.
2. Press and hold the volume up and power buttons simultaneously for about 10 seconds.
3. Release the buttons when you see the Android recovery screen. 4. Use the volume buttons to navigate to the "wipe data/factory reset" option and select it with the power button.
5. Confirm your selection and wait for the reset process to complete.
6. Once the reset is finished, select the "reboot system now" option.
Your tablet will now reboot and be as good as new!
3answers
How do i do a factory reset on a laser mid-1087 tablet please
My eTOUCH TABLET android tm 9 go edition was factory reset and I forgot verify pin anyone know how to fix this
2answers
My gigaset tablet is stuck on erasing screen , what should i do?
sticking charger in to laptop as it may not have enough charge into erase the tablet iv had this problem before
How do i reset my tablet back to factory setting currently lock out do to a google account
This is how Nick Liberatore of Loyola University describes it (it worked for me):
  1. Power off the tablet.
  2. Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power).
    You will see the word Start with an arrow drawn around it.
  3. Press Volume Down twice to designate Recovery mode.
  4. Press Power to restart into Recovery mode. You will see an image of an Android robot with a red triangle.
  5. Hold down Power. While holding down Power, press Volume Up.
  6. A menu in little blue type should pop up. Use the volume keys to scroll to "wipe data/factory reset" and press Power to select it.
  7. Scroll down to "Yes - erase all user data" and press Power to select it.
  8. When it says all data has been removed then choose to reboot the system.
  9. If you then see the welcome screen you'll know you succeeded!
What do i do when i have a 7 inch pandigital tablet/ereader in white and it has the button that pops open with an error that says force close and wont let me get passed that button because it keeps po
this is about the worst tablet you can ever buy
in the future spend more than 80 bucks either way here is the help you need to fix it it is called a hard reset
How to hard reset Pandigital Novel 7 to Factory Default Setting Reset Pandigital Novel 7 to factory default setting you will lose all of your sms and apps,so you must back up your apps and sms.
These steps will show you how to hard reset Pandigital Novel 7 to factory default settings:
First, try this:
1. Go to main home screen, press the menu button.
2. Choose the Privacy
3. Press Factory data reset.
4. Read the disclaimer, then Press Reset.
5. Last,press Erase everything.
6. Restart the Pandigital Novel 7, you will see the phone as a brand new phone.
2answers
How do i reset my android dragon touch tablet
Try holding power and both volumes if it reboots normally try again but let go of power when the Android pops up
Keeps constantly restarting
Warning: All applications and personal files contained on the tablet will be erased. Only do this if you are unable to start your tablet.
  1. First, ensure the tablet has been switched off.
  2. Hold both the VOL+ and POWER buttons until the Gemini logo appears. Release both buttons.
  3. You should see a green robot on the screen with a red warning sign.
  4. Press & hold POWER then press VOL+ once, then release the POWER button. A menu will show on-screen.
  5. Using the VOL+ and VOL- keys you can move up and down to select the Factory reset option. Press POWER to select this option, then move down to YES and press POWER again.
  6. Once completed, press POWER to restart the unit.
Acer iconia a500 tablet freezes at the boot screen and does not go any further
The following info from
http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
Good Luck!
1helpful
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
2answers
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
Top Acer Tablets & eReaders Experts
Marvin
Marvin
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
