Question about Ricoh Office Equipment & Supplies
How to fix error SC556 on ricoh - Ricoh Office Equipment & Supplies
Posted by Senior Geologist on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
It depends from machine to machine. on some you just need to enter into service mode and then copy sp or system sp. On other Ricoh machines you need to execute a reset. first of all turn on the machine, and make sure no print jobs are present, or remove the network print or USB print cable and then turn on the machine. This is just to make sure that no print jobs are present, because this will make you to not be able to enter in service mode. This code SC556 also and other similar SC codes like 551,552,544 and etc. are connected with the Fuser unit. Most of the time is just triggered as security for overheat to stop a melting or fire. So if you reset the machine with procedure you may make damage, but in most cases is harmless. But if you reset the SC556 and then after short time reappear than the machine have real problem and need to be fix, do not reset it more than to to times in a row on a short time period. To enter into service mode press the following keys in the following sequence: press the yellow(clear) - then press 1 0 7 (numbers on the keypad) - then press and hold it pressed the red stop button until service mode appear on the screen. when service mode appear on screen enter into (copy sp) or (system sp) depend from the model of the machine. Then with the keypad press 5-8-1-0-# on the screen should appear Fusing SC reset, press execute and after show complete turn off the machine and wait at least 30 seconds, turn it on again. if its ready the sc is clear. But if the sc repeat the machine have a serious problem with the fusing unit and need to be fixed, if you try to reset the machine with this reset to much in short time you may just add more damage. for more detail post the model of the machine.
Posted on Nov 29, 2018
2 Related Answers
Anonymous
  • 132 Answers
SOURCE: Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
temperature changes by
±20°C or more in one second.
This occurs three times in one
minute or two consecutive
times.
• Loose connection of
the pressure roller
thermistor 1. Check if the fusing unit is properly set
and connected to the main frame.
• Loose connection 2. Check if the pressure roller thermistor
connector is firmly connected.
between the fusing
unit and main frame
3. Replace the fusing unit.
Posted on Dec 01, 2008
Michel
  • 97 Answers
SOURCE: sc556
To reset fuser SC codes you need to enter Service Programme Mode and reset SP5-810 to 1, then turn the main switch off and on again. If you need help on entering SP mode etc. then take a look here.
Posted on Apr 19, 2012
How to fix error sc556 ricoh printer
1. Check if the fusing unit is properly set and connected to the main frame. 2. Check if the pressure roller thermistor connector is firmly connected
2answers
Printer Ricoh sp 210 su in error service call sc556
This is most likely a fuser issue. If you have a spare laying around, I would suggest replacing your fuser. If you have a contract with Ricoh, I would suggest placing a service call for them to come out and look at the machine.
2answers
How to solve service call sc556
Do what it says and call service.
Sc556
Ricoh DX4640PD priport machine with SC556 code - what is this, I can't get past it to open the drum unit or anything? Thanks
And how about error code SC553?i try log in test mode and use program clear mermory.the machine still code SC553
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
