Question about Chime Home
My sessions electric westminster chime mantle clock the small second dial moves real slow. can I repair wires
Posted by laura madrid on
5 Related Answers
Anonymous
SOURCE: Seiko Westminster Chime Clock; Model No. QQF150G Caliber 12105
Does this help
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
Anonymous
SOURCE: seiko mantle clock (switchable chimes)
See this site
Anonymous
  • 5 Answers
SOURCE: Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
Posted on Jun 05, 2010
Anonymous
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
cashley199
Charles Ashley
SOURCE: tempus fugit westminster mantle battery operated
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
Posted on Aug 18, 2012
I have a Daniel Dakota quartz mantle clock with Westminster chime but a black wire coming from chime housing and going in battery compartment came loose and it stopped chiming. I'm sure it's a simple fix...
It is the negative wire from the battery box that came loose. Need to solder it back onto the battery box negative attachment point. Have a good look at the battery box outer side where the previous soldering point should be visible and solder it back on at that point.
Nov 07, 2017 | Chime Home
Clock is ticking but not chiming
Have you ensured that the strike train is wound?
UsedClockParts.com
Nov 21, 2016 | Home
How do I stop the continuous hour chimes on a WESTMINSTER chime mantel clock ?
Is this a older type mantel clock or an electric. A older one has a small arm on the back of the wooden case just move it to it's opposite position and that should stop all chimes. A few times that small switch is on the inside but very rear. If it's electric it also should have a switch to turn off all chimes.
Feb 06, 2015 | Home
I have a Revere 913 clock. Keeps perfect time. Westminster chimes only work intermittantly by itself. Can activate chimes manually. It appears that the functions are in order, but will not activate by...
Hello Rterry6517,
Yes... you are right (CLOCKSMITH / movements).
Electric movements (original (telechron chiming type))
are very much the same as SPRING DRIVEN...
(in fact... the ones I have worked ARE spring driven
Merely THE WINDER is ELECTRIC)).
A CLOCK repair would be the wise choice...
Some people opt for the electronic conversions...
(my opinion they are quite a bit less of the true tones
of a well maintained clock motor and REAL CHIMES.
Hope THIS HELPS...
Carnac the Magnificent
Nov 20, 2017 | Watches
Tempus fugit westminster mantle battery operated clock has 2 buttons under an H and 2 buttons under an M. how do I set the chimes? Amy Howard
Feb 08, 2010 | Seiko Mantel Clock
Whitting and Westminster Jean luis Electronic clock
I found my own solution through trial and error. I set the dials to 12 00 and then move the dials to show just over 5 minuites to 12 ( 1155) the alarm melody start and chimes for a number ( in may case it was one.) then i moved the dial back to 1200 and then reset it again to 1155 or just over. Each time the alarm chimes an increasing number
I had the clock chime settings on the back of the clock to the middle setting (chimes on 24 hours)
I carried out this until the chime was right for the time i was working ( in my case it was 1730) so when it reached 5 chines I then set proper time and left it. The next chime was correct
Jan 09, 2009 | Seiko Mantel Clock
Home Logo
159 people viewed this question
Top Chime Home Experts
Marvin
Marvin
Vernon Taylor
Fahr Quad
Are you a Chime Home Expert? Answer questions, earn points and help others
