Question about Jensen Audio Players & Recorders
I miss placed my manual for Jensen jcr208a some how it got changed from waking up to music to a buzzing sound I want my music back how do I do that.
Posted by Debie Lecato on
Chris Huff
    Top Expert:
  • 6,289 Answers
Https://www.manualslib.com/manual/560570/Jensen-Jcr-208.html
Posted on Nov 28, 2018
How do I set the alarm on this model, which I cannot find any where. Grateful & puzzled. Model 7-4806A GE Clock Radio
SETTING THE WAKE TIME You can select two different wake times for music or alarm to turn on automatically. WAKE 1 and 2 controls are located on top of the unit behind the SNOOZE bar.
1. Slide switch to SET position. The display will change to wake time.
2. Use the FAST FORWARD, FORWARD and REVERSE buttons as needed until you reach your desired AM or PM wake time. For music, select an AM or FM station and then turn the radio off. Set wake time and then slide the switch to MUSIC. For Alarm, set wake time and then slide switch to ALARM position. If a wake time is set, an indicator in the display lights and the unit turns on in the chosen mode (alarm or music) at the set time for approximately one hour. To turn off the wake mode, slide the switch to OFF or press the OFF button. NOTE: If both Wake 1 and Wake 2 controls are in the SET position, the time of day is displayed. GE 7 4825 User Manual
1helpful
I don't have a manual for my GE clock radio model 7-4809. How do I set the alarm. FK
If it has a wake button, push and hold the wake button while you push the hour and minute buttons to set the time to wake. It may have an alarm button instead of a wake button. Then there should be a switch to set to wake to alarm sound or music.
2helpful
Can't turn off the alarm
There are two alarms, and the steps are the same .
Look on the face. On the left of the big numbers are two symbols, a 'bell' and a 'music note'. That's WAKE 1. On the right of the big numbers are two symbols, a bell and music note. That's WAKE 2. If any of these are on, then one (or both) alarms are set to repeat.
Stopping repeat Wake 1 alarm. Click the Wake 1 button (on the top) several times, while looking at the face. Notice the circles that light up. It will switch back and forth between bell and music note each time you press the Wake 1 alarm button.
HOLD DOWN the WAKE 1 button on the top, until both lights are off. The Wake 1 alarm is now off.
Wake 2 alarm: Same steps, but for the green circles on the right side of the face.
Get a piece of paper, write "HOLD DOWN WAKE BUTTON to stop repeating alarm" and tape it to the back of the clock.
2answers
I have this constant buzz from the speakers...I notice it less when music is playing but it is still there. what can I do?
Make sure that there are no magnetic interference to the speakers. Its should be because the speakers are kept near some electronic or magnetic device...
Just try moving the speakers and notice if there is a change in the buzzing, if yes... then its definitely some interference on them.
Get back to me if that does not resolve it.
1helpful
2answers
The alarm sounds daily. how can i stop it?
There are two alarms, and the steps are the same. Make sure both are off.
For Wake 1 alarm.
1.Look on the face. One the left are two symbols, a 'bell' and a 'music note'. 2. Press the 'Wake 1' button on top, several times. Notice how the green circle on the left of the face switches back and forth between bell to music note. 3. HOLD DOWN WAKE 1 BUTTON, until both lights are off. The Wake 1 alarm is now off.
Wake 2 alarm: Look at green circles on the right side of the face. HOLD DOWN WAKE 2 BUTTON until both circles are unlit. The Wake 2 alarm is now off.
1helpful
Jensen Jims-225 wake to Ipod trouble
In standby mode Press the >>I to select iPod/Radio/Aux/buzzer as a "wake to" alarm
Can not delete unwanted schedule
Remove the batteries and any power source for 10 minutes. This should go back to factory defaults. Sounds like a stat problem honestly. I would exit the program and change temps manually at all times.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2helpful
2answers
Changing between the buzz and cd setting for alarm clock
From the manual (miraculously, I still have it)...
To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
SNOOZE-BOOST
To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
