Question about Samsung Televison & Video
My samsung smart tv won't display subtitles even though I have turned CC on.
Posted by mayron tsong on
How do I get closed captioning?
According to the Samsung support website there is an option in the menu which is called "caption" which can be selected off or on.
This is a link to a copy of the manual.
Samsung UN65F6300AF manual
In the manual it says to select the onscreen menu and then ...
Subtitles
Screen Menu > Broadcasting > Caption Try Now
View subtitles along with subtitle-enabled digital and analog broadcasts.
Show Subtitles
Screen Menu > Broadcasting > Caption > Caption Try Now
Show subtitles. Subtitles will be displayed when you choose a broadcast that supports subtitles.
"" DVD Subtitles are only available when connected to an external input connector.
How do I turn the subtitles off for the yamaha HTR-5730 AV receiver? When I hook the cable up directly to the TV, there are no subtitles, but when the video output goes through the receiver, subtitles
The receiver manual may list it under "CC" (closed captions) instead of subtitles. Also, don't just check your AV receiver; try checking the setup menu on your TV, and look at the TV remote. See if there's a CC setting that may be turned on, either through the TV setup (probably under the "Display" or "Video" tab) or because you've accidentally pushed the CC (or Subtitles) button on the TV remote.
3answers
Subtitles always on
We believe you have the Closed Caption decoder in your TV enabled. Please turn off the CC feature in the TV.
Getting rid of subtitles on samsung smart tv
There should be a button on the remote control to turn on and off the subtitles. On three of my Samsung products the subtitle button is marked as "subtitle"
Best Regards,
I am deaf and must have subtitles (Closed Captions) when I view DVD movies, which I buy, rent, or get from the library. I have 3 DVD players, all set up to show CC. 95% of the time there is no problem. ...
Movies said have CC close captioning sometimes just an add on print.Must go to the movies main Menu.To see if it have a Title on the main menu said SUBTITLES English,Spanish or French.Press that SUBTITLES to get close captioning printing words on the screen.But if u push the underline word said SUBTITLES,nothing is showing up on the screen,than the DVD movie disc have a problems or the add on print said CC is a lies.That the world for u,nothing are 100%.
156helpful
21answers
Can't turn subtitles off
I want to thank whomever suggested the following...it works. I had been trying for days. Here is the solution:
Turn off the cable box and hit the menu button on the universal remote. The screen with the closed caption selection appears. Scroll down to the line regarding subtitles and turn it off.
2answers
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Open Questions:
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
