Question about Westclox Audio Players & Recorders
I'm looking for a manual for Westclox Big Ben moonbeam clock model 70034X
Posted by Carol Sweeney on
ch.vijaysagar
    Sergeant:
  • 272 Answers
5 Related Answers
Anonymous
SOURCE: Westclox Monarch Alarm Clock - Model No. 90003
While holding down the snooze bar that says "ALARM" on it, hold down either of the "HOUR" button to set the hour when the alarm should go off or hold down the "MINUTE" button to adjust the minutes for when the alarm should go off.  Switch the "ALARM" to "ON" when done.
Posted on Sep 03, 2008
Anonymous
SOURCE: how to get big ben clock back after changing wallpaper
Settings > Display Settings > Home Screen
Then change the first item marked 'images' to 'Dynamic' with the left/right buttons.
Posted on Oct 05, 2008
Anonymous
SOURCE: I need a user manual for the Westclox Baby Ben
I have not a manual, please, helme
Posted on Aug 21, 2009
Leobreaker78
Charles Luhrs
  • 5 Answers
SOURCE: I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
Posted on Jun 03, 2010
Anonymous
  • 823 Answers
SOURCE: Model westclox belleville quartzmatic
Your best bet would be to send it to the Clock Man in Fullerton, California and have him repair it for you. Here is a link to his website at the bottom of this post. My family has used his services for years & years without a problem.
http://www.theclockmanonline.com/
Call him and explain the problem you are having. If anyone can repair it, he can.
Posted on Jul 28, 2011
Have a beautiful Westclox Big Ben 1964 wind up clock. The person said he believed it was wound too tight. According to the owner:The Big Ben doesn't run (is wound tight), and the alarm only clicks when...
Sorry to say that clock repair is not easy and is a lost art. You may want to see if you can locate one locally that can fix it. The only other chance you have is to open the clock and look for the winding spring and the pawl that holds it and release the tension by holding the pawl back as you put torque on the winding stem, then release the stem slowly and then release the pawl.
Instructions for westclox bluetooth stero am/fm clock radio
Google search your manufacturer make and model and the word
manual. If one is available, you can find it in the search
results.
The alarm won't work on my nearly new moonbeam clock
go through the setting for alarm procedures as there may have been glitch that dropped the setting off
1helpful
Big ben moonbeam alarm not sounding
The later alarm trip assemblies - the one in which the cam on the trip staff is a steel disc with a cutout, and the trip wheel is steel with a stamped out projection - can be troublesome. I had so much trouble with these parts on a 1970 Big Ben leg model reproduction that I replaced them with the old style trip assembly having the brass finger on the trip staff and a brass trip wheel. This solved the problem of the trip staff being carried around with the trip wheel.
1helpful
1helpful
Design of back of clock
I know how you feel... it is hell to get old. Have you tried looking at second hand stores for the old original Big Ben? I changed over to electronic digital alarms with battery backup, but I'm with you... it is not the same. It is a good thing that time becomes less critical to us as we age... except having more of it. Perhaps you can go to Westclox website and click on CONTACT, and send them a message yourself. Better in your own words than mine. http://www.alarmclocksonline.com/BigBens.htm May God richly bless you.
Top Westclox Audio Players & Recorders Experts
nexrad_chris
Ngoro
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
