The right side of my newly bought jbuds air wireless headphones wont turn on at all. I've charged them held each side 3 seconds and then turned them off and held for 15 and it still won't light up white. Also I cannnot get the left one that does light up to connect to blue tooth
SOURCE: Will not let me connect the blue tooth to my phone
ur just a ********..haha nah jk
i got the same problem. help...
SOURCE: Brake light, reverse light and turn signal issues
Hello. The symptoms you are describing are likely due to a poor ground. Temporarily install a new ground wire by securing a piece of copper wire to the frame with a self tapping screw. Use this ground wire along with the hot wire to see if each of these lights works. If it does, trace the ground wire back to the frame, unscrew it and clean up the metal with emery cloth so you reestablish a good ground.
SOURCE: Trailer lights have two wire out of each fixture
One wire is for the brake/directional filament and the other wire is for the tail light. The fixture should be grounded when it is attached to the bracket. To test which is which (the brown wire is USUALLY the ail light) make sure the fixture is grounded and touch a hot wire to each of the wires coming from the fixture. Watch to see which wire lights up the brighter filament and this is the brake/directional light. The dimmer filament if the tail light. Brakes lights and directional lights are both the same filament. Wen the brakes are applied, both lights are activated. When a direction light is turned on, it simply flashes the brake light filament.
SOURCE: Bose Headphones only works on left side.
Have same problem. Play with the plug in the socket. I'll bet it you can occasionally get both working. Not a solution since it probably won't stay working. I have an old plug and it fails too. I'm afraid they did't make their plugs to the right tolerances. Used to work once. Annoying for this expensive a headphone.
