Question about Amana Kitchen Ranges
Outer portion of dual element amana cooktop (ARTSC8650WW) burner not lighting up and heats only minimally
Would like to know if it is the switch on the face of the stove that switches from small to full burner or the heating element
Posted by Teresa Reese on
Chris Huff
    Top Expert:
  • Amana Master
  • 6,289 Answers
It could be either. You will have to test voltage to burner. If it’s getting voltage to part of burner that’s not working, then burner is bad. If it’s not getting voltage, switch is bad.
Posted on Nov 27, 2018
5 Related Answers
Anonymous
  • 146 Answers
SOURCE: Large Dual Element Is Not Working
Check the center ring. If it is open replace it.
Posted on Dec 21, 2007
Benimur
Louie Role
  • 6966 Answers
SOURCE: Whirlpool electric Cooktop's one burner not heating
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: RCC3024 cooktop one burner wont heat
Hi again,
It would seem you posted anew.
For some reason I could not locate related literature for a RCC3024LD01,although there are for LB01, LQ01 and a LT01. Most of the components inthese models could be checked with the use of a continuity tester(multitester VOM/DVM). The idea is to check for continuity of eachcomponent. If we are to assume that the heating element as a likelysuspect, it is a matter of checking if the coil is continuous, that isno break anywhere in between. The test prods of the continuity testerwould be applied to the two (2) terminals of the heating element andthe tester should deflect/display how much is the resistance. Normalreading shouold be pretty low while no deflection/reading indicates anopen coil and therefore would require replacement.
These additional documents may be of help to you:
  1. exploded parts diagram;
  2. parts list.
Cheers.
Anonymous
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
dbxpert2
SOURCE: Whirlpool Flat cooktop burner not heating up
Try cleaning the knobs. I did the same thing you did (turning the circuit breaker off but that did not solve the problem.
My wife just tried turning the knobs and that seemed to work. It appears that one of the knobs may have been so sticky that the though it's in the OFF position it thinks it's still ON.
Posted on Mar 05, 2009
Electric Stove Burner won't shut off after element malfunction
(no model number received)
My best advise would be to cut the power at the
MAIN CIRCUIT BREAKER panel... and leave
the RANGE powered down until a new
ELEMENT and TEMPERATURE SWITCH are
installed... (very dangerous).
I am guessing... but I suspect the SWITCH got
SERIOUSLY DAMAGED when the element
did it's melt-down (live power my be present)
WITHOUT a model number that is
TOTAL SPECULATION...
Hardware stores commonly carry GENERIC
(UNSATISFACTORY ... in my opinion) SWITCHES.
I would got to a SERIOUS parts house and order
both the element and the SWITCH...
If you have your OWNERS MANUAL... Look
up the REAL PART NUMBERS on eBay
(for serious savings)...
ELSE
Try one of these part houses to find your parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Hope this helps
Carnac the Magnificent
Dec 19, 2017 | Kitchen Ranges
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
I turn my burner on at medium -no problem. When I
If you cannot regulate the temp on any surface element the problem is not in the element but rather the "infinite" switch. You need to replace the switch's if you can't control the hi and low on the burners. The switches will be different for the small burner and the large burner because of the different wattage on the burners.
Nov 11, 2009 | Kenmore Kitchen Ranges
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
My GE electric burner is not working.
The know that controls the burner is bad. Take off the front cover and replace the control knob. Be sure you unplug the stove. Let me know how it goes. ken
ps write down the wiring of the control there are 5 wires going to switch there will be little letters on the switch like l1 l2 P com on writing like that.
Dec 22, 2008 | GE JRS04 Electric Single Oven
Kenmore electric stove model c880.6383880 left front burner does not work....it is not the element itself as it heats up on another burner.
hi,
sounds like you have the old-style coil elements on you stove.
your problem is the switch under the element, called the infinite switch. i would suggest to have a technician replace it. they usually charge for the labour but if you have never done it before, it's money well spent.
Aug 19, 2008 | Stoves Kitchen Ranges
I want to replace an erratic element on a really old Viking stove. The new element plugs into a new recepticle,but the latter has 2 wires, whereas the old stove has 4 wires that were connected directly...
This can't be done. The old elements were a two part element with 2 seperate coils. The heat was controlled by using one or both elements at different voltages to select the heat output. The new 2 wire element just pulses the current on and off to control heat. It is just one big element. Try to purchase a generic replacement burner that will fit the hole. Usually these come with the chrome ring and everything. They are somewhat adjustable but will not match your existing burners. GE used to make this. Another possibility is if the control to the burner is a knob that turns, Replace the switch with a new infinate heat switch. If this switch will mount properly. Just grab the two 220 volt legs from the old switch, Ignore and tape the neutral, ground, and pilot leads. Connect to the line side of the switch. Use only 2 of the old wires going to the burner and connect them to the new one.
Jun 29, 2008 | Kitchen Ranges
RF367LXKQ burner light always on
YOU HAVE A BAD STOVE SWITCH,TAKE THE TOP BACK PANEL OFF STOVE,HOW FIND OUT WHAT COLOR WIRES GO TO THE STOVE LIGHTS,NOW ONE SWITCH AT A TIME REMOVE THOSE WIRES CHECK TO SEE IF LIGHT GOES OUT NOT RECONNECT WIRES AND MOVE ON TO THE NEXT SWITCH UNTIL YOU FIND THE BAD ONE THE REPLACE IT,HOPE THIS HELPS-MIKE
May 30, 2008 | Whirlpool RF367 Electric Kitchen Range
JBP75GS1WH 3 TOP BURNERS NOT WORKING
it could be bad connections at elements or bad elements a volt meter works good for this problem
Dec 10, 2007 | GE JBP60 Electric Kitchen Range
Kitchen Ranges Logo
79 people viewed this question
Top Amana Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
