Question about Samsung HP-R5072 50 in. Plasma HDTV
CANNOT SET UP REMOTE CONTROL
I HAVE SAMSUNG HP-T4254/HP-T5054 AND CANNOT SET UP REMOTE TO MY HUGHES ST BOX WITH MY SAMSUNG REMOTE
THERE ARE NO HUGHES ST B CODES IN THE INSTRUCTION BOOK
Posted by viewer1 on
Anonymous
All u have to do is pick only one code and go with that one if it doesnt work i will send u a code that will work
Posted on Dec 21, 2007
Samsung remote HP-T4254 need code please
If you need the code list for the original HP-T4254 remote, BN59-00599A, these are listed in the manual starting at page 22. The steps to program the remote are on the preceding page. Crutchfield has the manual on the product page: http://www.crutchfield.com/S-TYaga4aDv9F/p_305HPT4254/Samsung-HP-T4254.html . The direct link to the manual is http://pdf.crutchfieldonline.com/ImageBank/v20071022131600/Manuals/305/305HPT4254.PDF .
Please note that the codes programmed into the remote will probably not operate devices that are newer than the TV. Sometimes electronic devices that were released less than 6 months before the remote was programmed will not respond to the available codes in the given remote.
If you are trying to find a Samsung TV code that will work with another remote, please indicate which universal remote you are trying to program. (There is a Redi-Remote replacement for the BN59-00599A that does not function as a universal remote.)
I hope this helps.
Sep 18, 2016 | Samsung HP-T4254 42 in. Plasma Television
Tip
Input Switching issues Harmony Remote and Samsung TVs
The following 2008 Samsung TV’s have Anynet+:
LCD
All 9 Series LCD TVs (LNxxA950)
All 8 Series LCD TVs (LNxxA850, LNxxA860)
All 7 Series LCD TVs (LNxxA750)
Most of the 6 Series LCD TVs (LNxxA650, LNxxA630) excluding the 19” and 22” models
All of the 5 Series LCD TVs (LNxxA550, LNxxA540, LNxxA530)
Most of the 4 Series LCD TVs (LNxxA450) excluding the 19”, 22”, and 26” models
Plasma
All 7 Series Plasma TVs (PNxxA750, PNxxA760)
All 6 Series Plasma TVs (PNxxA650)
All 5 Series Plasma TVs (PNxxA550, PNxxA530)
Half of the 4 Series Plasma TVs (PNxxA450) excluding the 410 line (PNxxA410)
DLP
All 7 Series DLP TV’s (HLxxA750)
All 6 Series DLP TV’s (HLxxA650)
All 5 Series DLP TV’s (HLxxA510)
2007 Samsung TVs With Anynet+
The following 2007 Samsung TVs have Anynet+:
Note: Excluding all 26" models and below.
LCD
All 81F series (LN-Txx81F)
All 71F series (LN-Txx71F)
All 65F series (LN-Txx65F)
All 61F series (LN-Txx61F)
All 53H series (LN-Txx53H)
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Information on Samsung TVs that support AnyNet has been refered to from: http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=1&AT_ID=18104&ARS_ID=8514159
How To Disable Samsung Anynet+ so your Harmony Remote Control properly controls your devices. This mainly impacts Input Switching.
1) Press your Tools Button.
2) Scroll down to Anynet and press your Select Button.
3) Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4) Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, let me know
on Feb 10, 2010 | Logitech Harmony 520 LCD Remote Control
Tip
Input Switching Issues with Harmony and Samsung TV's
LCD
Plasma
DLP
LCD
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, please e-mail us back for further assistance.
on Feb 10, 2010 | Logitech Harmony 880 LCD Remote Control
Samsung hp t5054 light comes on but it has no pic, sound and does not click when plugged in
Check that all cables are intact and plugged in correctly. (VGA, DVI, Antenna etc.) Did you place batteries correctly?
There might only be one button that turns the TV on/off (usually a red button in the top of the remote).
Jul 06, 2014 | Samsung HP-T5054 Widescreen 50 Plasma HDTV...
Can't get my samsung hp-t4254 42" plasma tv to
make shure that the computer is set up to display on the screen. To check and see right click on your desktop, click on the option that says screen resolution, and then change your settings from their. The tv will not register that you have a computer plugged into it if the computer is not sending the tv a signal.
Mar 05, 2011 | Samsung HP-T4254 42 in. Plasma Television
Picture has gone pink and there is no sound - Samsung HP-T4254
It sounds like either the X-Main board or the Main Board has failed. I recommend calling 1-800-samsung to find the nearest service center to repair it. You can spend a lot of money replacing parts on a plasma before you find the defective part.
Jun 16, 2010 | Samsung HP-T4254 42 in. Plasma Television
Sound reset
http://www.retrevo.com/support/Samsung-HP-T4254-TVs-manual/id/2727dj896/t/2/
try this or simply pick your remote and press the menu key and then go in sound option and then reset the equalizer
Mar 27, 2009 | Samsung HP-T4254 42 in. Plasma Television
Samsung hp-t5054
use the blue (p.size) button on lower left of remote control
Jan 13, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
154 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
