Question about JVC MX-D402T Shelf System
Power failure. the power runs out.. even the standby signal is gone..  i have checked all the fuse all of them are ok.. what is the main problem?? please can you help me..
Posted by dennmark on
Anonymous
    Problem Solver:
  • 13 Answers
Try to check first your power cord,
Probably theres a cut on wire that give the flows of electricity
Posted on Nov 24, 2008
I have a Insignia NS-L32Q-10A that will not power on. Now power on light or standby. I have replaced the power supply already. All caps look good and fuses check OK. What next???
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Feb 02, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
VIZIO MODEL VW42LFHDTV10A WILL NOT TURN ON. FUSES &VOLTAGES OK
Did you check for the "ON" or "PS ON" signal on the power supply board? It should be around 3.3vdc.This signal comes from the main board, it commands the other sections of the power supply to come on and turn on the TV set. This signal should be present when you press the power button from either the TV or remote. If you are not getting this signal from the main board, you're most likely dealing with a main board failure. If you are dealing with a main board failure, take heed, some Vizio main boards can be expensive.
Sep 04, 2012 | Televison & Video
I got no picture but the sund is ok.It's a
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_24_2012_10_47_33_pm.jpg5_24_2012_10_47_54_pm.jpg
May 24, 2012 | Televison & Video
My lcd tv picture is gone
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_24_2012_4_15_54_pm.jpg5_24_2012_4_16_16_pm.jpg
May 24, 2012 | LG Televison & Video
No pictures
ISSUES:
Answers to issues:
May 04, 2012 | Philips 42TA648BX 42 in. LCD TV
Tv has no power,not turning on
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_23_2012_4_02_19_pm.jpg
Apr 22, 2012 | Konka KDL32AT23U 32 in. LCD Television
Toshibaq ctv 17WLT56B - troubleshooting
ISSUES:
Answers to issues:
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_3_2012_11_52_08_pm.jpg
Look for bad caps that look like this on the power supply inside the set.
Apr 03, 2012 | Televison & Video
Ok my tv will not stay on i unpluged it and it just blinks and turns off
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.4_2_2012_6_22_06_pm.jpg
Apr 02, 2012 | Televison & Video
The power failure in off and on
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.4_1_2012_2_49_19_pm.jpg
Apr 01, 2012 | Sony KDL-40NX700 40 in. LCD HDTV
No picture but sound is ok
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.3_27_2012_10_45_24_pm.jpg
Mar 27, 2012 | Televison & Video
JVC MX-D402T Shelf System Logo
106 people viewed this question
Top JVC Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
