Question about Laser Office Equipment & Supplies
How can i make copies on my clp 325 laser printer
Anonymous
SOURCE:
Anonymous
SOURCE: Samsung CLP 550N paper jams
Make sure the paper guides are not too tight and always fan the paper to rid static build-up before loading.
Posted on Dec 28, 2007
Anonymous
  • 8 Answers
SOURCE: Laser Printer Problem
Do a panic stop while the machine is in the middle of processing copy. Remove the imaging unit and lift the drum cover to view the surface of the drum. If the image produced on the drum is OK (ie.no ghost image) then focus your attention on the hot rollers just before the paper exit. Otherwise your problem is the imaging unit.
Posted on Feb 21, 2008
Anonymous
SOURCE: Purchased CLP-300 colour laser printer.
open front cover and on left is a light grey "L" shaped item with a finger grip indent. If this item is not there, you will have to buy one (about $15 +-) If it is present, pull it out all the way then re-insert it with some force but do not john wayne it. try starting again. Dont forget to open and close both front and rear doors on the machine to reset the start process. If this doesn't help, a trip to service may be in order. Also, the toner tank can be emptied but it is a very messy deal, remove it, tip it upside down and shake. Probably best to do this inside of of a large trash bag and seal it around your wrist. the now empty container can be wiped off good with a damp paper towell. install and try again.. happy printing.
Posted on Sep 30, 2008
Anonymous
  • 161 Answers
SOURCE: I have Samsung CLP/610 laser printer and need to
"MP tray" refers to the manual paper tray. This is the common setting for most word processors whenever printing media other than paper. This message will come not only for labels, but for transparencies, card stock, envelopes, etc. The reason for this is that the manual paper tray is designed to provide a straighter paper path that helps preventing your labels from peeling inside the unit. Therefore, I do not recommend placing them in the regular paper tray. Take note that you should also check that the labels purchased specify they are meant for laser printer or copier. Regular labels, or labels designed for inkjet printers will surely come off inside your printer and cause damage that the warranty will not cover.
Be blessed.
Posted on Apr 16, 2010
SamsuTech
  • 113 Answers
SOURCE: CLP-315 - CLP-315 Laser Printer: I have changed all the color toner but not prining...
any error indicated?
run your Smart Panel and check what is the fault that is being detected.
If all the color toner had been replace. what about the OPC & waste toner tank?
note. Please replace the waste toner tank once it is full do not reuse the same waste toner tank. as it will course the internal of the printer to be spread with waste toner and your print out will be dirty and patches.
Posted on May 21, 2010
Always shows "Printer offline" status (Mac OSX)
Have you installed the printer driver for the selected printer??
Oct 30, 2017 | Samsung Clp-325 Colour Laser Printer
Color stain
Laser, inkjet??? Model Make ??? You need to be more specific.it makes a difference on the type of ink used.
Sep 06, 2012 | Samsung Clp-325 Colour Laser Printer
Samsung clp-325 laser printer driver
You can download the Samsung printer drivers from theirsupport WEB site. Please click on this link
and select your model printer todownload :- http://www.samsung.com/au/support/main/supportMain.do
May 14, 2011 | Samsung CLP325 Laser Printer
I need the instruction booklet for a CLP-325. Can you email me a copy. Thks. Fred.
Is this a Samsung CLP-325? If this is here is the link where you can download the manual. Also for other manual for this printer including the quick install, please clink on the mainlink.
I hope I was able to help you with your concern.
Thank you for choosing Fixya.
Mar 05, 2011 | Office Equipment & Supplies
I want to know if the samsung colour laser printer has photocopy photocopy capability
As long as your asking about the CLP-510 then the answer is no. It is a PC printer only with no copying capability. Samsung does make some multifunction color lasers that will Copy/Print/Fax and Scan.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Samsung CLP-510 Laser Printer
I have a Samsung CLP-315 laser color printer. I'm trying to find out if there's a *.icc or *.icm color profile for it to use with Adobe Photoshop. Couldn't find anything yet via google or others. Would you...
I have just purchased a CLP 325 and have set it up to get excellent colour pictures using Adobe Photoshop and the icc profiles readily available.
Your current working icc profile could be either Adobe RGB (1998), sRGB, Profoto or another. I would suggest that for everyday work use sRGB, if you are a specialist use Adobe RGB (1998).
Firstly make these changes in Photoshop:
Edit / Assign Profile / ColourMatch RGB.
To print:
File / Print / printer profile should be Adobe RGB (1998)
Illustration attached
Aug 24, 2010 | Samsung CLP-315W Laser Color Printer
My Samsung CLP-300 Laser jet is "burning" the ink when printing mostly dark colors which causes it to bubble and flake off the paper.
What kind of paper are you using? This printer does not work well with glossy paper and will do the things that you have described. Try using ordinary 20 lb copy paper and see if this makes a difference. If you are already using copy paper, then the problem is with the fuser, getting too hot.
Aug 02, 2010 | Samsung CLP 300 Laser Printer
60 people viewed this question
Top Laser Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Barbat Nae
Barbat Nae
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
