Question about Life Fitness Exercise & Fitness
My life fitness elliptical, model with alternator starts control panel and after a few minutes it pauses and then shuts off no matter how fast you are going. There is not a battery as that’s what I though was the culprit. Any help would be appreciated.
Posted by Donald craver on
5 Related Answers
Anonymous
SOURCE: Gaggenau GI 936-760 dishwasher
Buy a new one and sell me the door. I have been looking for this model's door for a long time!
[email protected]
Posted on Dec 12, 2007
Anonymous
SOURCE: i cant seem to turn off my zune completely, only pauses
The Zune never really turns off completely. To turn it off, hold the back button and up on the Zune pad. As soon as the screen turns black, let it go, and turn on Hold.
This will turn it off completely.
Posted on Apr 16, 2009
vpaaf
Howard
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Posted on May 01, 2009
Anonymous
SOURCE: LIFE FITNESS elliptical 9500HR SHUTS DOWN
I don't know about the answer, but I seem to have the exact problem!
Posted on Feb 17, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: Where is battery located for Life Fitness 9500HR
These units are not self generating unit theirpower cords is in front bottom if it is missing then you will a power module got to www.sportsmith.net goto life fitness and get pricing
Posted on Mar 03, 2010
I changed the 6 volt battery when i connect the battery leads and used machine i press clear/pause button it will start again. I have to disconnect the battery to turn it off
If no key is pressed for 15 seconds, and the user stops pedaling, the console shuts down. You can also do the same when starting the machine, just step on the pedals to get them moving and the console should light up.
Dec 13, 2014 | Life Fitness 9500 HR Crosstrainer Rear...
Life Fitness 95xi elliptical electronic panel will turn on but after a few seconds the screen goes blank and evenutally starts back at start up screen.
I would suggest verifying 6 volts output from the battery. From there, check the reed switch connection on the power control board. Also verify the gap between the reed switch and the magnet on the pulley. It needs to be close enough to the magnet to get a good reading. I am attaching a link to a video that shows the reed switch replacement procedure. You can see the magnet and also the slots in the reed switch that allow the adjustment. LifeFitness 95Xi Crosstrainer Video Reed Switch Replacement Speed Sensor
Mar 18, 2014 | Life Fitness 95xi Elliptical Crosstrainer
Electrical issue.
check the battery or alternator that charges it. battery is usually front end and alt is in the back. if this is not it it could be the the controller board
Mar 18, 2014 | Life Fitness 95xi Rear Drive Commercial...
Where is the battery on the life fitness 95xi
The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure. Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Dec 29, 2013 | Life Fitness 95xi Elliptical Crosstrainer
Life fitness 95XI elliptical clanks
You may still have the original tie rod design on your machine. If so, more than likely this is your problem. The link below is the updated fix for the original design.
Control Link Kit LifeFitness GK62 00002 0071 SPORTSMITH net
Dec 16, 2013 | Life Fitness 95XI Elliptical Trainer...
95xi machine goes into pause mode when being used.
Check the gap between the magnet on the drive pulley and the reed switch that is mounted to the frame.
Aug 05, 2011 | Life Fitness Remanufactured 95Xi...
Exercise & Fitness Logo
172 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
