Question about Shop Vac Vacuums
Do I remove the filter from a shop vac before I suck up water?
Posted by Mary Jane Moore on
Barrie Luck
    New Friend:
    Problem Solver:
  • 9 Answers
Are you sure your vac CAN safely suck up water? It's not something you want to do if it can't.
Posted on Nov 25, 2018
5 Related Answers
Anonymous
SOURCE: shop vac
Vacuum is less than a year old and died in the middle of a use. No power... tried to plug it into 3 known, good outlets. Suggestions?
Posted on Jul 06, 2008
Anonymous
  • 10 Answers
SOURCE: DEWALT DW795 Vac filters
IT looks like the part number is 429704-56 and the Dewalt site shows list price being $51.68. You should be able to order that filter at a DeWalt dealer in your area, hopefully for a discount.
Otherwise, there is here online:
http://www.ereplacementparts.com/search_result.php?osCsid=2c10ce07c62a161bca9f80f981bf690f
Posted on Feb 26, 2009
Anonymous
  • 15 Answers
SOURCE: removing impeller from sears shop vac
The impellar will screw off with a clockwise rotation and the new one installed with a counter-clockwise movement.
Posted on Aug 21, 2009
Anonymous
  • 120 Answers
SOURCE: using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Posted on Sep 16, 2009
digritz
david mcclellan
  • 530 Answers
SOURCE: I have a 10 gallon Shop.Vac 3.0 but I don't have
Yes you should remove the filter for liquids. If the filter is not removed the internal float stop will not operate correctly. This will lead to the liquid being drawn up into the impeller and around the motor.
However I still like to have something in place because in most instances the liquid you vacuum up will not be without some solids. So I like to use a foam insert. Places like Home Depot carries a universal insert that works great.
Hope that helps.
Posted on Sep 17, 2009
My rigid shop vac 4.0 has no suction
If the motor is turning on then the issue is one of three things blocked exhaust, blocked intake or the fan that moves the air is loose on the motor . The last doesn't happen as much but can. First thing is to make sure the safety ball hasn't become stuck in the intake line. ( this ball stops water from reaching the motor when using it in a wet environment.. If the machine was knocked over while running or was used to suck up water the ball may be stuck) to fix this , remove the wheels from the bottom of the canister , with the machine off raise it and bang it on the floor several times . If you hear a ball drop then that was your issue. If not Disconnect the hose and see if you have suction at the intake. If you do the problem is a blocked hose. Reverse the hose and try sucking the other direction. If the exhaust is blocked the Vac will come on but the machine will sound like it's under load. Try running it without the filters ( do not use in dirt until filter is cleaned and replaced.,). To check the suction fan requires unplugging the Vac from the wall and opening the motor shroud . Locate the fan , see if it is damaged or loose.
Aug 01, 2018 | Shop Vac Vacuums
Why does the ball inside my shop vac stay stuck
if you are using vac to suck water the ball is a safety device. you must shut vac down and wait you should hear ball drop, if the vac is not in upright position he ball will close shut vac down and wait
Jun 20, 2018 | Shop Vac Vacuums
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Using shop vac 52722-90 for wet applications
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
HOW DO i GET THE WATER OUT OF THE CARPET ONCE IT'S CLEANED?
Do you have a shop vac . Take the bag out of the shop vac ,and **** up the water . When you are done open your windows and do not walk on the carpet for at least one hour . You want your carpets to dry with the pile standing up. Carpet rake is the best thing to use . Best of luck Ed.
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Set up the shop vac to pick up water
I figured I had nothing to lose so I just started vacuuming. I thought I had to turn the end of the hose that connects to the shop-vac around (which I did so that it brought the water down to the 'bucket'. Other than that, I even went to Yahoo Answers and asked for input. The answers were - just vacuum, they didnt think there was anything to do with the vacuum to set it up for wet vac. I had removed the cloth filter used for dry vacuuming so I was ok with that. I also saw a YouTube video that said basically to remove the cloth filter. Ok .... that was not so difficult. Thank goodness too.
Jul 26, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Jul 16, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Automatic pump for 10 gal shop vac
first you have to remove the filter in the vac then at the bottom of the vac tyhere should be a cap you remove and screw a water hose on and run it out side then when the vac fills the water will run out put the main hose on the suction side
Mar 21, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Vacuums Logo
131 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Bill Johnson
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
